Hey Mr Wizard / Dodge No Start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by scott 1, this thread has received 12 replies and been viewed 1121 times.
post #1 of 13 (permalink) Old 01-27-2010, 11:09 PM Thread Starter
Hey Mr Wizard! I've got a 98 24 valve with a no start issue. Has good fuel pressure, will start if given a sniff runs excellent after it fires. Will start an hour later, but let it set over night it will roll but not fire. Intake heater working fine, No smoke at tailpipe, Changed fuel filter, No codes are shown! The guy I bought it from says it hasn't been run since June of 09,
Whos got the wand!
scott 1 is offline
post #2 of 13 (permalink) Old 01-28-2010, 02:18 AM
Official TDG Doctor
hccumminssmoke's Avatar
Just b/c it has good FP doesnt mean that the IP isnt the problem...have you messed with the started any? checked hook-ups and fuses...any codes?
Nate
hccumminssmoke is offline
post #3 of 13 (permalink) Old 01-28-2010, 03:46 AM
Need to check for air leaks and/or bad lift pump to start
hin0031 is offline
post #4 of 13 (permalink) Old 01-28-2010, 04:48 PM Thread Starter
I Have more info guys! For Nate 2 new Batteries and starter was pulled and gone through. At pump inlet side I have 14 PSI, but with key on and truck not running I have a drip on the return side! Shouln't I have fuel pouring out! I'm thinking a stuck fuel shut off solonoid?
scott 1 is offline
post #5 of 13 (permalink) Old 01-28-2010, 05:38 PM
the 24v engines don't have the shutoff solenoid like the 12v engines.
kwswan is offline
post #6 of 13 (permalink) Old 01-28-2010, 07:28 PM
Official TDG Doctor
Have you run codes yet?
Nate
post #7 of 13 (permalink) Old 01-29-2010, 12:00 AM Thread Starter
Nate, And others --- Thanks for info. I originally had codes and cleared them all to see if they reappeared. Scanning again found 216, P-1689 P-0260 needless to say I guess I'll be needing a pump!
Do you know who's got A VP 44 for sale? Someone reputable?
Thanks Again!
Jeff
scott 1 is offline
post #8 of 13 (permalink) Old 01-29-2010, 12:03 AM
Official TDG Doctor
I run an II Pump, and I like it a lot...BlueChip also sells a good reman pump...idk which one is cheaper, you said you had good FP, are you running stock LP or aftermarket? II sells their IP and a FASS of your choice for a pretty good price...
Nate
post #9 of 13 (permalink) Old 01-30-2010, 05:49 PM
I run a scheid pump and love it. They also have a great reputation as well. If you're just looking for an SO pump to get you back on the road for a decent price, check with
www.dieselautopower.com He has a good price on pumps and I've talked to a lot of people that have been really happy with his pumps and service.
post #10 of 13 (permalink) Old 01-30-2010, 10:30 PM
When I did my VP44 I went with Blue Chip because of the great reputation he has for selling reliable pumps. He has 2 to choose from for the SO engines. The normal oem and the Special X VP44. I went with the Special X because it was only a few hundres dollars more plus had some aditional fuel economy and timing benefits. I will say I have been very happy since I put it in. Both pumps also come with the Bosch 1 year warrantee.
cumminsdude2001 is offline
Strange Cold start/no start/start changexlt 2003-2007 6.0L Power Stroke 7 12-23-2008 09:00 PM
Rough start and white smoke at cold start? bassn_07 2003-2007 6.0L Power Stroke 11 03-02-2008 10:57 PM
04-17-13 Hard Start Or No Start - Gpcm Connector Service Kit Available - 6.0l Engine Squatch Ford Oasis requests 0 03-23-2007 11:55 AM
CRANK NO START, HARD START, RUNS ROUGH AT IDLE - 6.0L 2005 F, E-Series,and Excursion PSDPlayer 2003-2007 6.0L Power Stroke 0 10-08-2005 07:32 AM
? for an exhaust Wizard 2towrjp 2003-2007 6.0L Power Stroke 11 08-26-2005 06:21 PM
