1999 not going over 22 psi - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cummins power, this thread has received 16 replies and been viewed 1965 times.
post #1 of 17 (permalink) Old 01-27-2010, 11:38 PM Thread Starter
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
1999 Cummins, Auto with new TC and shift kit, 4x4, K&N air filter, 4" exhaust, Edge Comp, divider in exhaust housing ground out, 3.55 gearing on 35's.
I put a boost controller on it, and we even tried putting vice grips on the hose going to the wasegate. We're trying like hell, but can not get this thing over 22psi of boost. The air filter is clean, fuel filter has only 1000 miles on it, no boost leaks we can hear. It smokes until about 20 psi, then it's clean up to 22 psi. I was thinking lack of fuel, but fuel pressure gauge stays up good. I have come to the conclusion that the ECM is defueling it, but I do not understand why because I thought the Comp was a fooler and keep the fuel going? We even tried putting my old stock HX35 on there, same thing. Only other thing I can think of is that the auto isn't loading it enough, but I know other rigs with auto's making more than that.
Logan
Do Or Die Garage Experiment
cummins power is offline
post #2 of 17 (permalink) Old 01-28-2010, 05:16 AM
bmoeller's Avatar
What are the EGTs like?
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 17 (permalink) Old 01-28-2010, 05:39 AM Thread Starter
Hot Rod Farm Boy
I turned 21
1100-1200 max
Logan
post #4 of 17 (permalink) Old 01-28-2010, 05:45 AM
Cummins diesel power!!!
what setting are you runnin on your comp box??? on my edge with level 6 i easly hit 1500 egt.. and i wired the waste gate shut on my 01' and i can hit 35 psi and if i have the smoke switch on i got smoke til 28 psi
cummin 723 is offline
post #5 of 17 (permalink) Old 01-28-2010, 06:01 AM Thread Starter
Hot Rod Farm Boy
I turned 21
Pretty sure he's running it on 5x5. Far as I know it's not anything special, no Hot Unlock, not a Drag Comp. I was also recently informed this pickup has 160,000 miles on it on the factory original VP44. It has the in tank booster pump which was put in between 50,000 and 60,000 miles. Could it possibly be heading south?
Logan
post #6 of 17 (permalink) Old 01-28-2010, 06:18 AM
yaa i say so at 130k i put a new vp44 and fass pump(had a bad run in with bio) and the truck ran a whole lot better,, but i know that the in tank booster pump is junk, id say he needs to put a real lift pump on it...but does the truck feel like it dogs out at 22 psi??
01' Dodge 3500 dually 4x4 285/75/16's auto(with billet goodies and tc) 4.10 gears, k+n intake,the silencer ring fell outta my turbo ,edge juice w/att. w/hot,smoke switch,4' strait pipe w/6' tip, fass 95,
post #7 of 17 (permalink) Old 01-28-2010, 02:39 PM
Official TDG Doctor
hccumminssmoke's Avatar
HX35 Blocked Wastegate I could turn 40psi Comp on 5x5 no problem...
Nate
hccumminssmoke is offline
post #8 of 17 (permalink) Old 01-28-2010, 08:30 PM
ya but dosent a hx 35 start to over spin at 35 psi??? or 37?? leaving them couple extra pounds usless??
post #9 of 17 (permalink) Old 01-28-2010, 09:02 PM
This does not sound good.
later is offline
post #10 of 17 (permalink) Old 01-28-2010, 09:06 PM
Official TDG Doctor
never said it was healthy
Originally Posted by later View Post
Unless someone put a HX35 on the a 01 or 02 they should have a HY35 with the 9cm housing on it.
Nate
One more try. 1999 F-250 powerstroke2003 Whats Been Sold 3 01-29-2009 04:35 PM
1999 s10 8 Strokin Whats Been Sold 1 12-25-2008 07:43 PM
1999 7.3l turbo jmbstudios 1994-2003 7.3L Power Stroke 14 03-04-2008 07:47 PM
1999 F-350 sprintracer27 Whats Been Sold 17 11-22-2007 05:02 PM
Did the 1999.5 have a cat?? two-rocks 1994-2003 7.3L Power Stroke 12 07-24-2007 11:26 PM
