2001 codes? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by CoryStudebaker, this thread has received 5 replies and been viewed 1058 times.
post #1 of 6 (permalink) Old 01-31-2010, 01:47 AM Thread Starter
2001 codes?
On my truck it shows p500 and 1693 i guess i dont know if either of these codes would cause my problem though. Its problem it when its getin to about 2000rpm it acts like its runnin out of fuel but i dont think it its. it starts like missing and shaking really bad. the reason i dont think its running out of fuel is because i just change my fuel filter and it my pressure guage show 17psi and thats at he injection pump. could it be my injection pumps going out or somthing else. let me know what you guys think. thanks
CoryStudebaker is offline
post #2 of 6 (permalink) Old 01-31-2010, 04:04 AM
Official TDG Doctor
hccumminssmoke's Avatar
well 0500 is a no speed sensor code...and 1693 is a companion code...Did you get the filter housing tight? What all is done to the truck mod wise?
Nate
hccumminssmoke is offline
post #3 of 6 (permalink) Old 01-31-2010, 12:28 PM Thread Starter
Yea i got the filter housing tight, this problem is the reason i changed the filter and it still did it. The truck has stage 5 injectors cold air intake and a edge drag comp.
post #4 of 6 (permalink) Old 01-31-2010, 03:33 PM
is this only going on while on level 5? If so you need to get your computer reflashed you have a program in the computer that adds timing and your over timing the thing.
01quadcab is offline
post #5 of 6 (permalink) Old 02-01-2010, 12:47 AM Thread Starter
No this happens wether the chip is off or on on any level. could it possibly be doing this because of an injector. I usually just drive it to school and its only 5 miles and it really never get wormed up fully. Today i took it on a 40 mile drive to town and got it good and warm and it ran fine on all levels and never did surge or anything. Also this problem started around the begining of December. I know on one of our older tractors that when its cold it missis but when it warms up its fine, could this possibly happen to my truck?
post #6 of 6 (permalink) Old 02-10-2010, 01:31 PM
Send a message via MSN to n-r-zigs
fuel delivery problem
you may have starved the injection pump ,the lift pump is not providing enough fuel resulting in injection pump damage, your symptoms are just what i experienced ,i tried to check every thing starting cheap, the end result was the purchase of an injection pump 1690$$ cand.. and about 5 hrs labor, if this is your problem make sure you have fuel pressure to the pump when you install the new one
neil :mafia ziegler
n-r-zigs is offline
2001 isc Dualie Medium and Heavy Duty 3 05-28-2009 10:34 PM
codes for 1999 to 2001 dt444e and dt466 dns recovery Medium and Heavy Duty 0 02-06-2008 09:15 PM
2001 Kw Isb ? fjh Medium and Heavy Duty 3 01-06-2008 05:53 PM
2001 buy or not Cold fodged 5.9L Cummins (1998.5-2002) 10 06-08-2007 09:39 PM
99 to 2001 CTD wrongway Whats Been Sold 0 05-29-2006 03:35 AM
