Fuel froze/gelled now I have codes. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by acesneights1, this thread has received 5 replies and been viewed 827 times.
post #1 of 6 (permalink) Old 01-31-2010, 04:23 PM Thread Starter
acesneights1's Avatar
Hey guys. I loaned the Dodge to my driver to get home yesterday cause his Ford(Patooie!!!)gasser commited suicide in my driveway. It was -15f the night before. The Dodge was pluged in but he said it started dying and the CEL came on , After a few minutes he said it cleard itself up and seemed to be ok. He put some anti gel in it. I got it bck today and it has the following stored codes(I won't post the 1693's)PCU 0122 and ECU1690. I am thinking the sensors went nuts cause the fuel either gelled or froze. I'm gonna run up to Advanced and get them cleared. Should I be worried about anything ?
1986 CUCV....M1008 6.2 NV4500 5 spd
Raptor 100 LP. Serp belt conversion. 5 inch redneck master exhaust. DB2831 IP. Dmax fan. Humvee waterpump.
1981 AM General M35A2c
Lee's Auto Ranch In Ellington CT SUCKS !!
acesneights1 is offline
post #2 of 6 (permalink) Old 01-31-2010, 08:22 PM
bmoeller's Avatar
0122 = Accelerator Position Sensor (APPS) Signal Voltage Too Low
1690 = Problem in fuel sync signal. Possible injection pump timing problem. Low power, engine derated, or engine stops.
Given the engine stalled, I'd clear the codes and see if they come back.
Also reset the APPS, and go from there.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 6 (permalink) Old 01-31-2010, 09:36 PM Thread Starter
How do I reset the APPS ? I went down to Advance and had the codes cleared and drove it to Tractor Supply and back, a good 30 miles or so. No codes...
post #4 of 6 (permalink) Old 02-03-2010, 05:05 AM
bmoeller's Avatar
IIRC, you need to disconnect the batteries for about 30 minutes. After reattaching them, turn the key to the "run" position, but do NOT start the truck. Slowly and steadily push the throttle pedal to the floor and slowly bring it back. Turn the key off, then restart the truck. Should be good.
bmoeller is offline
acesneights1 (02-03-2010)
post #5 of 6 (permalink) Old 02-03-2010, 01:14 PM Thread Starter
Thanks. Since Advanced cleared it it's running fine with no codes so I'm leaving it alone...
post #6 of 6 (permalink) Old 02-04-2010, 10:08 PM
bmoeller's Avatar
Good deal.
bmoeller is offline
Fuel system gelled. Need Help snownutz 2008-2010 6.4L Power Stroke 18 01-05-2010 12:50 AM
Gelled fuel/ Damage to IP- NEED HELP!!! dannyboy403 5.9L Cummins (1998.5-2002) 7 01-18-2009 12:55 AM
Fuel delivery, EGR, Codes Firemech 6.5L Diesel Engine 1 01-22-2008 01:27 PM
Hell Just Froze Over.. blackcloudCTD95 The Parking Lot 19 12-18-2007 12:08 AM
06 fuel codes redneckchief 5.9L Cummins (2003-2007.5) 2 07-04-2007 12:54 AM
