valves - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 99Cummins24V, this thread has received 3 replies and been viewed 913 times.
post #1 of 4 (permalink) Old 01-31-2010, 08:44 PM Thread Starter
valves
Can anyone explain how to adjust the valves on my truck. It has 247000 miles on it and I am told that it should be done and is possibly a power loss
99Cummins24V is offline
post #2 of 4 (permalink) Old 01-31-2010, 10:28 PM
Official TDG Doctor
hccumminssmoke's Avatar
On the ISB engine,remove the cap in the frt cover in frt of the fuel pump.remove the rocker cover bolts.The rear bolt will not come out.It will be left in the rocker cover for removal & installation.There is the a TDC mark on the frt cover & a line on the fuel pump gear.turn the line either at 12 oclock or 6 oclock position.Intake vavles are 0.010 & Ex valves are 0.020.You will need a 9/16 or 14 MM wrench for lock nut & 5 MM allen for screws.When at 12 oclock adjust exhaust vavles on 1,3,&5 cyl.Intake on 1,2,74.Turn line to 6 OCLOCK & adjust exhaust on 2,4,& 6 cyl.Adjust intake vavles on 3,5,& 6.
Thats outta the Haynes Manny
Nate
hccumminssmoke is offline
post #3 of 4 (permalink) Old 02-01-2010, 06:09 AM
All I would add is to turn it with a turning tool or slowly off the damper mount bolts you do not want to over-tighten the injection pump gear retainer nut. Intake is 1, 2, and 4
Johnp3 is offline
post #4 of 4 (permalink) Old 02-01-2010, 05:31 PM Thread Starter
Thanks. I am going to give this a go tonight.
how to set valves kennyhammond 5.9L Cummins (1998.5-2002) 3 11-10-2009 01:01 PM
94-98 12 valves Cummins5390 5.9L Cummins 12 Valve (1994-1998.5) 8 12-10-2007 07:25 PM
No more delivery valves mrector 5.9L Cummins 12 Valve (1994-1998.5) 11 09-18-2007 08:59 PM
Pop off valves?? tahoedmax Duramax 2001-2004 (LB7) 14 02-21-2007 04:28 AM
New to 24 valves! CanadianCarGuy 5.9L Cummins (1998.5-2002) 10 02-07-2006 01:33 AM
