24v problems - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kwswan, this thread has received 5 replies and been viewed 1058 times.
post #1 of 6 (permalink) Old 02-03-2010, 08:55 PM Thread Starter
24v problems
got a 99 model 24v in a 3/4 ton 4x4 with auto. trans. i had to replace the inj. pump & lift pump.replaced both,gave it a shot of ether & fired it up. started & ran good, drove down road about 4 miles & back home,ran better than it has in a long time. when i try to start it back,it doesn't want to. when it does it misses & blows white smoke.if you let it sit overnight,it will fire with ether but not by itself. after starting it will run great,but when you cut it off,same thing.missing,running rough,& smoking.talked to pump shop,they sent me a new pump,same thing.i replaced the cam pos. sensor while i had the pump off. took the truck to autozone & had codes checked. none showing. i am wondering if this could be the crank pos.sensor. any suggestions? thanks
kwswan is offline
post #2 of 6 (permalink) Old 02-04-2010, 04:17 AM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
i know this is a dumb question but where did you get the injection pump and did you put it in yourself? and what is you fuel pressure?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #3 of 6 (permalink) Old 02-04-2010, 12:27 PM Thread Starter
pump was bought from dis in louisville ky. yes i installed.airdog 100 was installed at same time. fuel pressure is good.
kwswan is offline
post #4 of 6 (permalink) Old 02-04-2010, 11:28 PM
ol ok i was just wonderin tho, i got a pump from thedieselstrore.com and they gave me 2 defective pumps before i got a hold of a good one, Did you put the keyway at 12 o'clock? Also did you check for any air leaks?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #5 of 6 (permalink) Old 02-04-2010, 11:38 PM Thread Starter
keyway was checked & is good. checked for air leaks but i am going to check again.
kwswan is offline
post #6 of 6 (permalink) Old 02-04-2010, 11:44 PM
ok, maybe check your apps sensor for the adjustments for it, im running out of idea's
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
The Following User Says Thank You to 97CumminsTurboDiesel For this addition to TDG:
kwswan (02-05-2010)
SCT add problems? Rww 2003-2007 6.0L Power Stroke 7 01-01-2008 06:36 PM
DPF problems ??? HElp !!! groceryman 6.7L Cummins (2007.5-2011) 5 09-17-2007 06:59 AM
Anybody ever have these problems? Blk350on20s 2003-2007 6.0L Power Stroke 14 02-14-2007 02:48 AM
Electrical problems/dash problems curtis2003 5.9L Cummins (2003-2007.5) 1 10-21-2006 08:27 AM
Air Bag Problems King of Obsolete Medium and Heavy Duty 10 07-02-2006 05:04 PM
