No power - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kccoon, this thread has received 7 replies and been viewed 981 times.
post #1 of 8 (permalink) Old 02-05-2010, 01:42 AM Thread Starter
No power
hi my friends 99 that was stock till 2 weeks ago was drivin along tonight and fell on its face. it is hard to get even 2000 RPM out of it. I put a edge chip on it. It still runs smooth would this be a VP problem
thanks in advance.
kccoon is offline
post #2 of 8 (permalink) Old 02-05-2010, 03:26 AM
Remove the chip and see if it still does it. then check for Any codes.
hin0031 is offline
post #3 of 8 (permalink) Old 02-05-2010, 07:56 AM Thread Starter
ok i removed the chip then disconnected the batteries to clear the check engine light. We then went for a drive the power was back but it threw the check engine light again. i dont have a code reader so as long as there arent any drive ability issues im going to hope the light goes back out.
kccoon is offline
post #4 of 8 (permalink) Old 02-05-2010, 08:28 AM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
Fuel filter
Logan
Do Or Die Garage Experiment
cummins power is offline
post #5 of 8 (permalink) Old 02-05-2010, 11:17 AM
u should be able to get the codes by cycling the key 2-3 times.
hin0031 is offline
post #6 of 8 (permalink) Old 02-06-2010, 05:05 PM
cowboytw13's Avatar
not on the 99's...you need to have a code reader
cowboytw13 is offline
post #7 of 8 (permalink) Old 02-12-2010, 01:11 PM
bmoeller's Avatar
Go to Autozone. They'll let you use a reader in the parking lot for free.
I'm guessing you need a new lift pump.
"Obama = Hoax and Chains"
bmoeller is offline
post #8 of 8 (permalink) Old 02-12-2010, 06:23 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Has the fuel filter been changed. Also did you check the fuel pressure of it?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
Cheap ATS E POWER 6.0 POWER STROKE murdered out Ford Parts 0 11-07-2009 01:23 AM
FORD SUPER DUTY 6.7L POWER STROKE DIESEL - Power Rating Discussion & Poll Scorpion6.7L 2011+ 6.7L Power Stroke Diesel 7 11-03-2009 02:38 PM
Converting from non power to power seating. boosted_blazer General Ford Truck and Excursion 0 02-17-2009 02:09 PM
No power steering or power brakes bigdaddy1 5.9L Cummins (1998.5-2002) 7 01-24-2009 04:53 PM
How much additional power by turning up the full power screw? colofred 5.9L Cummins (Pre 1994) 11 04-05-2007 09:26 PM
