Rump, rump, rump - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by carolsman, this thread has received 10 replies and been viewed 1162 times.
post #1 of 11 (permalink) Old 02-05-2010, 10:56 AM Thread Starter
Cool Rump, rump, rump
1999 3500 4wd 5.9. Here's the deal. Got a rump rump rump sound in reverse coming from the right front. Also I was backing yesterday with the wheels turned to the right and it felt like the drive train locked up. I pulled forward and straightened the wheels and was able to back normally (without locking or binding). Still had the rump rump noise. No, I was in 2wd.
Another thing.....My fuel guage isn't working. (I've got the sending unit). I checked my fuel mileage by the amt of fuel used by mileage. Everyway I figure, I'm getting a little over 2mpg. What's up with that? I just bought the truck, so I don't know the history. Anything you guys/gals can suggest? I appreciate it!!!! Ted
carolsman is offline
post #2 of 11 (permalink) Old 02-05-2010, 01:12 PM
I would say that the wheel bearing is on it's way out.Better check it. it can get expensive very quickly if you don't.
kwswan is offline
post #3 of 11 (permalink) Old 02-06-2010, 10:46 AM Thread Starter
Sooooooo, any ideas on the fuel consumption deal? Thanks
post #4 of 11 (permalink) Old 02-06-2010, 06:57 PM
recheck your math
2013 Ram 3500 Crew 6.7L 6x6 auto
11 Chevy 1500 ext 4x4 5.3L
07 3500 Crew 6x6 6.7L 6spd manual Edge Juice w/attitude, banks ram air box, 4'' exhaust, egr delete, south bend dual disk, boss 9' 2'' power v
Dads Ride 04 3500 Crew 4x4 5.9L Auto Larime 5'' exhaust, air bags
Bros ride 04 3500 Crew 6x6 5.9L Auto Stock
00 3500 Ext cab Dually 3.55 gears, 4'' MBRP, K&N, edge juice w/ attitude, rev maxx stage 4 converter, custom built tranny, Air Dog 150
98 3500 Ext cab Dually 3.55 gears handshaker, 4 into 5 exhust, edge juice w/att, BHAF
86 k2500 5.7 gas 3.73 gears, lock right front, warns,(My Hunting Beater)
King is offline
post #5 of 11 (permalink) Old 02-06-2010, 10:33 PM
cowboytw13's Avatar
Your only getting +-70 miles to the tank?? Is there fuel leaking all over the place while the truck is running?
cowboytw13 is offline
post #6 of 11 (permalink) Old 02-10-2010, 03:14 PM Thread Starter
No fuel leaks. Went 36 miles on 13.5 gallons????? 2.6666666 MPG
post #7 of 11 (permalink) Old 02-13-2010, 08:46 PM
99 cummins
customdeluxe78's Avatar
WOW! not to be smart but it sounds like you should have checked this truck out a little better before you bought it! i agree with the wheel bearing, however the fuel consumption is crazy! i don't see how an engine can make that much fuel dissapear like that. check again for leaks. does it run ok other than that?
99 cummins, 5-speed, edge comp, speedhut guages, fass 150 system, s&b cold air intake, ces two piece manifold, 5 inch straight exhaust with a 6 inch tip, 5 inch superlift, 4:10 gears, dynatrack lock in lock outs, 35x14.50 thornbirds on 16.5x12 mickey tompson classic 2's, alpine head unit, 1600 watt amp, 2 12 inch subs
customdeluxe78 is offline
post #8 of 11 (permalink) Old 02-14-2010, 10:12 PM
bmoeller's Avatar
Pull the dipstick, too. Fuel in oil? Speedo at all accurate?
I get FAR better mileage than that, just pulling gravity flow wagons all day long.
"Obama = Hoax and Chains"
bmoeller is offline
post #9 of 11 (permalink) Old 02-24-2010, 12:57 AM Thread Starter
replaced the hub and the rump rump is gone. Up to average 14mpg. Gettin better. No fuel in the oil. Thanks guys!!!
By the way......got another question. ABS light, fuel light, brake light, all on, and fuel guage reads empty. Put new pads on the front when I replaced the hub, and yes got the wiring correct on the sensor. The lights were on before I did any work. Some guy that says he is a diesel mechanic and knows Dodges said it was a Body Sensor Module<<<never heard of such. Any ideas???? I'd hate to run out of fuel. Thanks in advance
post #10 of 11 (permalink) Old 02-25-2010, 03:48 PM
PhilipR's Avatar
Fuel sender in the tank is shot...common issue. As for the ABS light.....is your speedo jumping around any?
-Phil-
PhilipR is offline
