Fuel pressure! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kc04, this thread has received 6 replies and been viewed 1056 times.
post #1 of 7 (permalink) Old 02-08-2010, 05:55 PM Thread Starter
Its Cute Aint it!!
Fuel pressure!
Wheres the best and cheapest place to get one. I dont care what flavor or nothing like that. The one i have i got from my buddy but i need another one and they are freakin gold! I would like to get one with all the plumbing and hardware!
04 smarty beta 4.4 and mp-8 , superchip stickers on the windows. SOLD
Wifes 04.5 4x4 smarty and dr p box exhaust intake and new rubber 502-1162 as of 12-02-09 With mostly stock tranny. Suncoast converter and valve body.
Dad 08 swb 4x4 h&s 5in turbo back egr block edge hot unlock and crappy clutch
98 12v 5spd 4.10s bhaf, exhaust, fuel plate, 4k gsk, timing, pump mods, and 300s Studs, o-ringed head, 3 piece manifold and 5in KDP tabbed, 60lb springs, titanium keepers
Moms 03 6spd- intake, smarty jr!!
01 reg cab dually 4x4 5spd bhaf raptor 150 and comp box Farmboy 5in 2in steel spacers for the rear with 6 new 305s! injectors on the way!!!!!
kc04 is offline
post #2 of 7 (permalink) Old 02-08-2010, 07:34 PM
Official TDG Doctor
hccumminssmoke's Avatar
Throw a post in the vendors section, im sure they can hook ya up
Nate
hccumminssmoke is offline
The Following User Says Thank You to hccumminssmoke For this addition to TDG:
kc04 (02-08-2010)
post #3 of 7 (permalink) Old 02-15-2010, 02:52 AM
acesneights1's Avatar
I like Autometer Full sweep myself but that is the opposite end of cheap..
1986 CUCV....M1008 6.2 NV4500 5 spd
Raptor 100 LP. Serp belt conversion. 5 inch redneck master exhaust. DB2831 IP. Dmax fan. Humvee waterpump.
1981 AM General M35A2c
Lee's Auto Ranch In Ellington CT SUCKS !!
acesneights1 is offline
post #4 of 7 (permalink) Old 02-16-2010, 01:08 AM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Ive went with glowshift. pretty sweet, you can also change the color and their a decent price too with all the works!!
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #5 of 7 (permalink) Old 03-03-2010, 01:30 PM
2nd Gen Guru
Mopar1973Man's Avatar
A little find for plumbing a mechanical gauge... (Copy from my site)
I discovered something today... For all of you that have mechanical fuel pressure gauges that are direct plumbed can have even more safety now. I found that you can get 1/8" air brake line at NAPA for cheap. The nice part is that the air brake line is rated well above 150 PSI (which I hardly doubt a 15-20 PSI lift pump will blow) and it extremely flexable. So if you kink the line it doesn't break off like oil pressure gauge tubing. This is Polyon Air Brake line.
My problem was where my old school big line kit has the tap in the line for gauge is in between the filter and VP44 so every time I would work on my truck I would flex line so much I break it off. Now I got to head to town get a ferule and replace it again. Well that is gone and over... I bought 10 feet and 4 ferules for $6.00 buck even. Cheap fix and no longer got to worry about that line now...
Even sitting here right now I'm flexing that piece of scrap line and I can fold it over in half and straighten it out over and over and it just snaps back. No holes or breaks yet...
Mopar1973Man is offline
post #6 of 7 (permalink) Old 03-09-2010, 12:12 AM
This is for the air side of the isolator ... no fuel correct?
dieselautopower is offline
post #7 of 7 (permalink) Old 03-09-2010, 12:55 AM
2nd Gen Guru
Direct connection to the fuel to the gauge...
Fuel pressure & rail pressure gauges??? SS1156 5.9L Cummins (2003-2007.5) 9 07-23-2009 06:33 PM
Fuel pressure & overflow valve pressure Deeslfxr 5.9L Cummins (1998.5-2002) 4 01-09-2009 11:35 PM
Setting fuel pressure regulator w/out a fuel pressure gauge hhrecovery 2003-2007 6.0L Power Stroke 17 04-02-2007 02:25 PM
Fuel Mods: X-over vs full fuel kit and pressure... bakantor 2003-2007 6.0L Power Stroke 39 03-10-2007 02:06 PM
$100 Off DJ's FUEL+ - Fuel Pressure Intensifier MOMBENZ Supporting Vendors Forum 3 12-13-2006 01:49 AM
