high idle? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cummin 723, this thread has received 5 replies and been viewed 1022 times.
post #1 of 6 (permalink) Old 02-09-2010, 05:14 AM Thread Starter
Cummins diesel power!!!
high idle?
does any body make a stand alone high idle controler??? something that you can adjust the rpm and how long it idles before it goes into high idle. I heard there is a "power idle" in the quadzilla that does high idle but I'm not switching over to that just for the high idle. Thanks!!
01' Dodge 3500 dually 4x4 285/75/16's auto(with billet goodies and tc) 4.10 gears, k+n intake,the silencer ring fell outta my turbo ,edge juice w/att. w/hot,smoke switch,4' strait pipe w/6' tip, fass 95,
cummin 723 is offline
post #2 of 6 (permalink) Old 02-10-2010, 03:21 PM
Singles Club #2
smokndiesel7588's Avatar
you can make your own...just need some switches, wire and resistors i believe...all layed out here -> http://mopar.mopar1973man.com/tips/c.../high-idle.htm
Greg
smokndiesel7588 is offline
post #3 of 6 (permalink) Old 02-10-2010, 05:00 PM
Official TDG Doctor
hccumminssmoke's Avatar
smarty or a brick
Nate
hccumminssmoke is offline
post #4 of 6 (permalink) Old 02-12-2010, 01:39 AM Thread Starter
Ya but i still need a smarty to enable the software in the truck to do this.
post #5 of 6 (permalink) Old 02-25-2010, 10:34 PM
2nd Gen Guru
Mopar1973Man's Avatar
High idle switches are well worth it...
Mopar1973Man is offline
post #6 of 6 (permalink) Old 02-26-2010, 11:53 AM
bmoeller's Avatar
http://www.midwestdieselconnection.c...ead.php?t=3515
"Obama = Hoax and Chains"
bmoeller is offline
Skweeker Mod (High Idle or Aux. Idle) CBSuperduty Ford - Modification instructions, Product installs and Tech Articles 23 12-31-2009 03:22 AM
High Idle & High Idle Kicker... Mopar1973Man 5.9L Cummins (1998.5-2002) 4 12-25-2008 01:36 PM
High Idle & 3 Cylinder Idle Mopar1973Man 5.9L Cummins (1998.5-2002) 11 11-02-2007 01:44 AM
high idle Dieselpower01 5.9L Cummins (1998.5-2002) 10 05-09-2007 08:56 PM
High Idle on its own...? Zaairman 1994-2003 7.3L Power Stroke 10 04-13-2007 05:28 AM
