fuel gauge issue - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cummins81888, this thread has received 4 replies and been viewed 675 times.
post #1 of 5 (permalink) Old 02-11-2010, 12:28 PM Thread Starter
fuel gauge issue
have a 01 24v not getting power to the sending unit hooked another sending unit up still didnt work any one know anything else
cummins81888 is offline
post #2 of 5 (permalink) Old 02-11-2010, 01:48 PM
Sounds like a broken wire or bad fuse.
mine had a broken wire along the frame
hin0031 is offline
post #3 of 5 (permalink) Old 02-11-2010, 03:01 PM Thread Starter
checked wires non are broken fuses are good
post #4 of 5 (permalink) Old 02-11-2010, 07:37 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
maybe a bad gauage.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #5 of 5 (permalink) Old 03-03-2010, 01:33 PM
2nd Gen Guru
Mopar1973Man's Avatar
Do a cluster test and verify the gauge is working...
http://mopar.mopar1973man.com/tips/c...uster_test.htm
Then check for error codes because if the sender is bad it will throw a code...
http://mopar.mopar1973man.com/tips/c...rror-codes.htm
As for if it is a bad sender (which I guess it would be) you can purchase just the sender for about $70 bucks from a local Dodge Dealer...
Mopar1973Man is offline
Fuel tank issue teamrope 7.3L and 6.9 IDI (Pre 1994) 10 02-09-2009 07:01 PM
fuel issue or is it??? colorado7.3 7.3L and 6.9 IDI (Pre 1994) 2 03-27-2008 01:23 AM
fuel gauge issue mckey73 Duramax 2001-2004 (LB7) 8 07-29-2007 02:51 PM
Fuel issue TheDiesel 7.3L and 6.9 IDI (Pre 1994) 4 07-27-2007 03:59 AM
98.5 fuel issue huntingman270 5.9L Cummins (1998.5-2002) 20 01-21-2007 03:43 PM
