24V Street Turbo assistance - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BombDocDiesel, this thread has received 12 replies and been viewed 2615 times.
post #1 of 13 (permalink) Old 02-13-2010, 10:50 PM Thread Starter
TDG Mafia Goon
BombDocDiesel's Avatar
I am cutting Chum down to a RC/SB and keeping her 2WD. I am already sourcing studs and injectors. I am pretty sure I'm going with ARP, just deciding on which ones I really need.
Injectors and turbo/turbos is still in the air. I would like to keep this project at $4500-5000.
My goal is 500-550 RWHP. I want to be streetable. I may tow occasionally but never heavy. This will see the 1/8 track near my house and the dyno.
I have some ideas on turbos and I'm researching compounds everyday. Compounds are looking good since they shouldn't lag as much as a large single.
I would really appreciate input from the folks that have upgraded turbos or went to compounds.
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
post #2 of 13 (permalink) Old 02-14-2010, 09:35 PM
********* and Mafia #90
Bcarriveau's Avatar
Moved into 24valve section!
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
The Following User Says Thank You to Bcarriveau For this addition to TDG:
BombDocDiesel (02-14-2010)
post #3 of 13 (permalink) Old 02-14-2010, 11:52 PM Thread Starter
TDG Mafia Goon
Thanks Bill. The cutting begins when I get back from this trip.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
post #4 of 13 (permalink) Old 02-15-2010, 04:33 AM
I made 488 with a 62 and 110 ddp's with edge juice with attitude and hot unlock. I think I needed more fuel. You can hit 500 with a set of 150's and a 62. It will be easy to drive and tow just fine.
01quadcab is offline
The Following User Says Thank You to 01quadcab For this addition to TDG:
BombDocDiesel (02-16-2010)
post #5 of 13 (permalink) Old 02-15-2010, 05:11 AM Thread Starter
TDG Mafia Goon
How was the low-end? This will only weigh 5500 pounds or so. I want to make sure it's good off the line.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
post #6 of 13 (permalink) Old 02-15-2010, 07:05 AM
I was running a 62/71/14 it can be a little laggy, but if your going to spool it and launch it you will not have an issue. I hear if you get a 13cm housing you will have better bottom but about the same top as the 14. Your going to be 1200lbs lighter than my truck is. at 488 I was running 12.92 but I had a loose converter so if you run a tighter one it will help. I am getting my trans gone through this week before the season starts. I used my 62 as the top charger in my compounds and now it's making 603 runs 12.38. running in 4wheel with 33's.
post #7 of 13 (permalink) Old 02-16-2010, 12:30 AM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
I would look at a 62/68/13SS for that kind of horsepower.
Logan
Do Or Die Garage Experiment
cummins power is offline
The Following User Says Thank You to cummins power For this addition to TDG:
post #8 of 13 (permalink) Old 02-16-2010, 01:17 AM Thread Starter
TDG Mafia Goon
I'm obviously a newb on this. Can you guys give me a brand or model to look at? I know of a couple 62s.
My first thought was a Garrett PowerMax stage III; GT3788R with 52 trim comp wheel, 0.99 A/R, Comp mm/trim 88/52, Turb Whl mm/trim 72.5 / 78
This will be 2WD running an Allison 5-speed with a Precision converter.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
post #9 of 13 (permalink) Old 02-16-2010, 03:36 AM
mine is just a version of an s300. I would not go with that big of an ar as that will be some huge lag as a single. .85 is what the 14cm is and it's laggy. super b special or similar turbo.
post #10 of 13 (permalink) Old 02-16-2010, 03:51 AM Thread Starter
TDG Mafia Goon
So, something like an II Silver 62? I've seen those. I'm still learning and trying to understand the maps now that I can find more than just the ones on Garrett's site.
Do I need to keep the turbine or compressor A/R low?
I'm drawn to Garrett based on my Duramax.
Thanks for the help!
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
Biggest Turbo on the street? dbeach 5.9L Cummins 12 Valve (1994-1998.5) 27 02-02-2010 02:39 AM
Innovative Tunes - Street or Xtreme Street? cartmanea 2003-2007 6.0 Tuner Forum 57 05-11-2009 02:13 AM
LIPD Pro-Street Turbo - $2000 caddy-cat Whats Been Sold 2 01-11-2008 10:15 PM
bwd 61mm turbo, dyno, street file...vid hotpursuit 2003-2007 6.0L Power Stroke 3 11-30-2007 09:15 PM
LIPD Pro-Street 64 Turbo 6L PWR 2003-2007 6.0 Tuner Forum 19 08-08-2007 01:09 PM
