01 cummins - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by [email protected], this thread has received 12 replies and been viewed 1616 times.
post #1 of 13 (permalink) Old 02-15-2010, 04:06 AM Thread Starter
01 cummins
what will happen if i unplug my map sensor? will it go in limp mode?
post #2 of 13 (permalink) Old 02-16-2010, 12:36 AM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
Pretty sure it will throw a code. If it does do anything other than idle, it won't be much because without the ECM getting a signal that there is air, it won't give you fuel.
Logan
Do Or Die Garage Experiment
cummins power is offline
post #3 of 13 (permalink) Old 02-17-2010, 01:47 AM Thread Starter
well true but i've heard it will smoke more
post #4 of 13 (permalink) Old 02-17-2010, 12:52 PM
Official TDG Doctor
hccumminssmoke's Avatar
It will throw a code, for no boost (i think)
Its basically like putting a smoke switch on it, you will see smoke, it calls for fuel with no boost...
Nate
hccumminssmoke is offline
post #5 of 13 (permalink) Old 02-17-2010, 03:58 PM Thread Starter
alright thats what i thought..just wanted to make sure
thnx.
post #6 of 13 (permalink) Old 02-17-2010, 03:59 PM Thread Starter
alright thanks..thats what i thought but i just wanted to make sure.
post #7 of 13 (permalink) Old 02-18-2010, 01:47 AM Thread Starter
where would the mapping sensor be located at?
post #8 of 13 (permalink) Old 02-18-2010, 04:14 PM
Hot Rod Farm Boy
I turned 21
The Manifold Air Pressure (MAP) sensor is on the intake manifold.
Nate
I think it might put out a puff just off idle, but it will only give you so much fuel without boost. Then when the boost comes up and the ECM still thinks there is no boost, it will be running lean.
Logan
post #9 of 13 (permalink) Old 02-18-2010, 05:26 PM
Official TDG Doctor
it will only give so much, but it will give more...
Nate
post #10 of 13 (permalink) Old 02-19-2010, 12:38 AM
IDImonsterstack's Avatar
when i first got my truck i unplugged it and all it did was throw a code and absolutly no smoke at all and felt like it was running on three cylinders. if ya want a lil smoke without a chip put a smoke switch in for about 5 bucks if that. but SW's are hard on the computer and is about as good as throwing money out the window but it is nice
IDImonsterstack is offline
Looking to buy my first Cummins 12V OzarkSaints General Dodge Discussion 4 10-09-2009 12:21 PM
Cummins l-10 300 R33615 Medium and Heavy Duty 8 10-03-2009 01:18 AM
NEW 03 Cummins BEHR2010 5.9L Cummins (2003-2007.5) 3 05-18-2009 01:45 AM
Cummins Conversion Adapter 460 to cummins Dieselwrencher Diesel Conversion 0 05-23-2007 05:29 AM
Cummins Conversion Adapter 460 to cummins Dieselwrencher Whats Been Sold 0 05-23-2007 05:29 AM
