cummings running hot - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by stotztowing, this thread has received 15 replies and been viewed 20447 times.
post #1 of 16 (permalink) Old 02-15-2010, 04:18 PM Thread Starter
i have a 1999 dodge ram 3500 ,its all stock,it pulls great use no oil or coolant has 220000 miles but it has always don this and so did my 1998. i have also talked to a few people around here who also have the same issue, when you pull a load up a long hill u drive by the temp gauge sure u have the power but cant use it because the temp gauge starts climbing fast i have never had a over heat but it gets to close for comfort so u got to back out and hold it around 35 mph i pull the same trailer up the same with my 454 i just grab a gear and hammer it no problem does any body know if this is a common issue with these as i have talked to several people with the same issue
stotztowing is offline
post #2 of 16 (permalink) Old 02-16-2010, 12:51 AM
********* and Mafia #90
Bcarriveau's Avatar
Moved
100K miles on 4/7/2010
2005 F250 FX4 Supercab Shortbed
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #3 of 16 (permalink) Old 02-16-2010, 06:31 AM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
Have you checked the thermostat? Do you know what your EGT's are doing? Then I would wash out the radiator/intercooler/ac condensor. Then make sure your fan clutch engages.
And please, it's Cummins not Cummings.
Logan
Do Or Die Garage Experiment
cummins power is offline
post #4 of 16 (permalink) Old 02-16-2010, 11:40 AM
How high are you keeping the RPM?
later is offline
post #5 of 16 (permalink) Old 02-16-2010, 02:34 PM Thread Starter
changed the t-stat clutch fans perfect external cores look good but i pulled it apart and washed them any way its almost impossible to get a good clean out without removing radiator so we will see if that helps any keeping rpms about 2000 to 2300.
i have been turnig wrenches commercially for 30 years now so i have checked all the normal things but i deffinately appreciate any and all suggestions
post #6 of 16 (permalink) Old 02-16-2010, 06:41 PM
On my 02 the fan clutch does not kick in until the water temp hits 195 and on a hot summer day pulling a 7K load it will come on, on the hills we have some 7% grades, and I can pull them running 70 mph with that load. The pyro will go up to 1100 sometimes a little higher but I am only running RV275 injectors, a edge comp box, and a 4 inch exhaust. So I am thinking you may want a timing box to advance your timing and cool thing off that way plus get a little better mileage.
later is offline
The Following User Says Thank You to later For this addition to TDG:
stotztowing (02-16-2010)
post #7 of 16 (permalink) Old 02-17-2010, 01:02 PM
milkin cowboy
MILKINGCOWBOY's Avatar
Send a message via AIM to MILKINGCOWBOY
You say hot, how hot? The stock temp gauge leaves alot of room for guessing. I pull 20,000 and on hills the temp will climb no doubt but then it will level off and hold. I would suggest a edge juice with attitude then you have a better way to monitor what its doing and if you think it pulls now just wait! I always ran 454s before my Cummins and the are great for a gas engine,but use fuel,get hot, and after 200,000 its time for a fresh one. Your Cummins should out pull it and do it cooler.....get the edge and you wont be disappointed at all and I would watch the pyro and drive by that before the water temp and use that as a secondary. I think there might be something wrong with truck or maybe gauge or sending unit if it truly getting that hot, they dont run hot with light loads good luck
2002 3500 6 speed ex. cab 4x4 custom flatbed farm truck 9,120 lbs. light weight ALL WAYS HAULIN HAY, CATTLE OR A-$-$!!!! BHAF,4" OPEN STACKS,EDGE JUICE WITH ATTITUDE, AIR DOG II 100,SOUTH BEND CLUTCH
1982 IH Transtar Eagle 4370 turned up 400 Cummins big cam, straight 6" bull haulers one hell of a
Jake and 13 speed od
White 2-105 tractor with 354 Perkins
White 2-135 tractor with 478 White/Hercules
KEEP ON KEEPIN ON
SUPPORT AMERICAS DAIRY FARMS
http://i17.tinypic.com/4u2drv8.jpg
http://profile.myspace.com/index.cfm...ndid=137814954
MILKINGCOWBOY is offline
post #8 of 16 (permalink) Old 02-21-2010, 08:12 PM
bmoeller's Avatar
I would remove the temp sensor, clean the threads on the sensor and where it screws in. Might not be making good contact.
"Obama = Hoax and Chains"
bmoeller is offline
post #9 of 16 (permalink) Old 02-22-2010, 04:28 PM
Steamclean the radiator. Just did it to mine and it makes all the difference.
#23 B.O.M.B. Squad[/B]
rwhite is offline
post #10 of 16 (permalink) Old 02-22-2010, 05:03 PM
Let it all Ride
Eazydeezy's Avatar
I think the problem is you have a cummings under your hood and not a cummins. Those darn knock off engines seem to be a big problem. It has something to do with the faulty flux capicters they installed into the doohicky.
Dominic
Eazydeezy is offline
new Cummings owner here goodriddance 5.9L Cummins (2003-2007.5) 7 01-18-2010 01:54 PM
L10 cummings mcquown84 Medium and Heavy Duty 3 08-17-2009 09:25 AM
Cummings and Excusion imported_99powerstroke Road Kill, Bench Racing 25 08-07-2007 12:11 PM
looking for a Cummings? Rcannon The Parking Lot 7 07-11-2007 02:29 AM
My Dodge TK with Cummings Redneck 5.9L Cummins (Pre 1994) 10 08-26-2005 08:29 PM
