RAPTOR - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kc04, this thread has received 8 replies and been viewed 1400 times.
post #1 of 9 (permalink) Old 02-17-2010, 03:54 AM Thread Starter
Its Cute Aint it!!
RAPTOR
Ok guys got my replacement pump from pure flow friday. I just got home with a wrecker ride! This has taken a dump on me. It only made 240 miles. Whar now my gauge is screwed so i wasnt able to watch it. I dont know what to do 3x in 4 months my truck has run out of fuel so im sure injector pump will be next. Do yall think its bad pumps or could it be something in the tank that keeps eating them up? I checked relay and fuse on pump and its fine. I need help cause if its something with my truck eatin pumps i need to figure it out. I kinda got nasty with the guy at pureflow about it but could it be my truck! The first one i got in october and it went out 2 weeks ago and this one has made it 4 days! But before 2 weeks ago it has been flawless.
04 smarty beta 4.4 and mp-8 , superchip stickers on the windows. SOLD
Wifes 04.5 4x4 smarty and dr p box exhaust intake and new rubber 502-1162 as of 12-02-09 With mostly stock tranny. Suncoast converter and valve body.
Dad 08 swb 4x4 h&s 5in turbo back egr block edge hot unlock and crappy clutch
98 12v 5spd 4.10s bhaf, exhaust, fuel plate, 4k gsk, timing, pump mods, and 300s Studs, o-ringed head, 3 piece manifold and 5in KDP tabbed, 60lb springs, titanium keepers
Moms 03 6spd- intake, smarty jr!!
01 reg cab dually 4x4 5spd bhaf raptor 150 and comp box Farmboy 5in 2in steel spacers for the rear with 6 new 305s! injectors on the way!!!!!
kc04 is offline
post #2 of 9 (permalink) Old 02-21-2010, 03:37 PM
bmoeller's Avatar
I'd be looking at your truck for the problem at the moment. Get that fuel press gauge working, too!
How is it plumbed and wired?
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 9 (permalink) Old 02-21-2010, 11:15 PM
Just looking at some of your old post, it looks like you may have other problems. Is your truck still throwing codes? You may want to trouble shoot all of the problem not just the easy stuff.
later is offline
post #4 of 9 (permalink) Old 02-28-2010, 11:44 PM Thread Starter
Its Cute Aint it!!
Well its the ip and trying to get monry together. I took old one to bosch place here in town and pump is bad!
kc04 is offline
post #5 of 9 (permalink) Old 03-01-2010, 12:24 AM
acesneights1's Avatar
I did a long thread on a Bad Raptor install. I suggest you read it. Lots of good info and covers just about everything that could possibly go wrong thanks to the skumbags at Lee's Auto Ranch in Ellington CT.
1986 CUCV....M1008 6.2 NV4500 5 spd
Raptor 100 LP. Serp belt conversion. 5 inch redneck master exhaust. DB2831 IP. Dmax fan. Humvee waterpump.
1981 AM General M35A2c
Lee's Auto Ranch In Ellington CT SUCKS !!
acesneights1 is offline
post #6 of 9 (permalink) Old 03-03-2010, 01:17 PM
2nd Gen Guru
Mopar1973Man's Avatar
Hmmmm...
The first thought to mind is that a Raptor 150 doesn't have a pre-filter to protect it from debris. So that is the first thing to check that the tank is full of dirt and debris. Then check the fuel lines to be sure there not sucking air or plugged up.
Mopar1973Man is offline
post #7 of 9 (permalink) Old 03-04-2010, 02:34 AM
Have yuo checked the Voltage at the LP while it's running ? Beleive me, this is where a test light doesn't cut. My problem turned out to be that it was only getting about 4 volts because of bad battery connections by the sc umbags at Lee's Auto Ranch. The test light lit up but it was getting resistance. Also I personally think the relay Pureflow uses is not HD enough. I have burned a few up. I carry a jumper wire and a spare relay. I'm going to eventually rewire a continous use Soleniod like the Meyers PLow Pumps use.
post #8 of 9 (permalink) Old 03-04-2010, 09:06 PM Thread Starter
Its Cute Aint it!!
Well doesnt ip send signal to lp. I took raptor off truck and put on my buddys truck and my truck did the same thing with his raptor. Its some thing with my truck. I keep getting p0230 that for lift pump and p0216. But pump was bosch and they said it was bad. Truck has 225k on origanal pump so new ip aint gonna hurt it but once i get new one and it still happens im gonna get a lil furhter into it!
kc04 is offline
post #9 of 9 (permalink) Old 03-06-2010, 01:55 PM
2nd Gen Guru
No...
The LP signal is directly from the ECM without a relay. If you take notice to the fuel pump relay in the PDC that is for the VP44... Also thr G107 ground is located behind the starter and requires you to remove the starter to access this ground.
As for the error code P0230 its pointing to the fact that either the Ampere rate is too high or too low for the lift pump.
New Raptor 150, bad IP? Buster 5.9L Cummins (1998.5-2002) 35 11-01-2009 12:18 AM
Raptor! woodsman The Parking Lot 19 02-25-2009 02:42 AM
Raptor 700 9512valve ATV, UTV, Dirtbike Forum 25 02-24-2009 12:35 AM
bad ***** raptor 700 02bigstrokin Whats Been Sold 1 12-02-2007 11:41 PM
05 700 raptor efi JPscustoms Whats Been Sold 0 09-06-2007 07:40 PM
