Blue foggy smoke? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hin0031, this thread has received 8 replies and been viewed 776 times.
post #1 of 9 (permalink) Old 02-19-2010, 02:31 AM Thread Starter
Blue foggy smoke?
When I start the truck, I notice a thick blue foggy smoke coming out of the tailpipe and have noticed it really doesn't completly go away. Truck has Quadzilla mileage max with a 4" straight exhaust thats it. any ideas?
hin0031 is offline
post #2 of 9 (permalink) Old 02-19-2010, 04:22 AM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
From what i know blueish smoke is oil burning. Check your oil pressure gauge and see how much oil you got.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #3 of 9 (permalink) Old 02-19-2010, 01:43 PM Thread Starter
Oil is fine. Seems to be the heaviest at start up and idling cold. Somewhat goes away after it warms up but not totally.
hin0031 is offline
post #4 of 9 (permalink) Old 02-19-2010, 02:02 PM
Send a message via MSN to n-r-zigs
fuel is not burning completely,could it be possible a injector is not giving a proper spray pattern , here in canada, 6 mounths a year it looks like that, until you get things warmed up
neil :mafia ziegler
n-r-zigs is offline
post #5 of 9 (permalink) Old 02-19-2010, 06:41 PM Thread Starter
! Thanks for the info. I know lots of people in Canada and they all say that you guys have 9 months of winter and 3 months of bad sledding! But again thanks for the info, i was thinking thta was what was wrong.
hin0031 is offline
post #6 of 9 (permalink) Old 02-25-2010, 10:17 PM
2nd Gen Guru
Mopar1973Man's Avatar
How about fuel pressure and error codes???
I know in really cold temp blue smoke is common but it normally goes away in a short amount of time. Typically when smoke of this type starts to hang longer is usually got a P0216 error code and/or low fuel pressure too (below 10 PSI)...
I dont want to scre you but check up on it and make sure...
Mopar1973Man is offline
post #7 of 9 (permalink) Old 02-26-2010, 01:36 AM Thread Starter
No codes. truck has new fass and inj pump on it. This has been going and is slowly getting worse. Truck runs excellent but yet my mileage is going in the tiolet. I am thinking injectors? how bout you?
hin0031 is offline
post #8 of 9 (permalink) Old 02-26-2010, 03:35 PM
Check for leaks or anywhere air can get into! It maybe a defective pump or a bad fass system!
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #9 of 9 (permalink) Old 03-02-2010, 01:42 PM
2nd Gen Guru
Well it could be a leaking injector too... If you find a good shop they pop test them for you for nearly nothing... But from what I understand is that the blue smoke with continue constantly.
Another is turbo seals... If the turbo is wore out the seals it might be leaking oil in the exhaust too... (another possibility)
White smoke blue smoke low on coolant whats wrong littlebigrig6.0 2003-2007 6.0L Power Stroke 24 12-05-2009 11:11 PM
quite a bit of blue smoke Langford 2003-2007 6.0L Power Stroke 23 12-03-2007 07:05 PM
7.3 IDI Blue Smoke valleylandscape 7.3L and 6.9 IDI (Pre 1994) 4 03-20-2007 01:39 AM
Blue smoke???? strokersmoker20 5.9L Cummins (1998.5-2002) 11 02-19-2007 01:36 AM
