5.9 question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fastgreek, this thread has received 8 replies and been viewed 1041 times.
Poll: What should i do?
Poll Options
What should i do?
post #1 of 9 (permalink) Old 02-23-2010, 10:00 PM Thread Starter
fastgreek's Avatar
5.9 question
well, i just sold my 13.5 's on stock turbo 04.5 cc/sb duramax and i really miss it, i was looking to get a reg cab duramax ( and make it run mid 12's with same options as my cc/sb) a friend of mine owns a used truck dealership and i drove a 2006 reg cab cummins for the first time and i really liked it, 19,xxx miles loaded except for leather and no xm radio ( love this in gm models), i know i can add it as well he is asking $29,900 and i am really debaiting buying it ,but, i found a 2000 cummins with a 100,000 miles on it for $6500 and i am thinking to myself what if i buy the 2000 cummins and add $10,000 with of performance mods with the trans being built i might be heading in a better direction.Is there any motor differences between the 2006 and the 2000 that i should know about? what do you think......
2004.5 LLY CCSB (Sold)
fastgreek is offline
post #2 of 9 (permalink) Old 02-23-2010, 10:19 PM
I guess the big question is how much will you be able to spend on the 06. I feel you could build a strong running 2000 with 10K plus the truck.
The 06 is a common rail and usually a better engine than a VP, but with care or a P-pump swap you can make the 24V a strong runner. There are many ways to approch this.
later is offline
post #3 of 9 (permalink) Old 02-23-2010, 10:27 PM Thread Starter
fastgreek's Avatar
well i can spend the same on performance, i just figured maybe i can save a couple thousand dollars going with the 2000 but i really enjoyed the 2006 , nothing like having a newer truck
post #4 of 9 (permalink) Old 02-25-2010, 04:33 PM
Singles Club #2
smokndiesel7588's Avatar
I would go with the common rail. Just beef up the tranny, add exhaust, intake and gauges...then buy a smarty. claims 170 hp on level 9. http://www.madselectronics.com/Smarty06.html
Greg
smokndiesel7588 is offline
post #5 of 9 (permalink) Old 02-26-2010, 03:42 AM
no matter what both trucks will need to have the trans built sooner or later. I think the 00 is better for the cost. Build the trans add a ppump and some big injectors and some twins.
01quadcab is offline
post #6 of 9 (permalink) Old 02-26-2010, 03:43 AM
I might even sell my 01 it runs 12.38 with the old trans the new one will be done next week in time for the whittman race.
post #7 of 9 (permalink) Old 03-03-2010, 01:21 PM
2nd Gen Guru
Mopar1973Man's Avatar
The only thing that sucks about CR engines is when you eat the injectors they cost MUCH more than a VP44... As for injector failure on CR engines is rather common unless you beef up the filter system (2 micron).
Mopar1973Man is offline
post #8 of 9 (permalink) Old 03-09-2010, 02:38 AM
Its totally within the realm of possibility with either platform. I like my VP truck, there are a lot of people that have hot rodded CR trucks. They are just easier to make fast, because the fuel system is superior to the older VP44. I say go with the VP truck. It wont be hard to make it run mid 13's.
post #9 of 9 (permalink) Old 03-09-2010, 03:05 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
Your CC/SB should have been able to dip into 12's with a good EFI tune, or PPE hot plus 2
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
Turbo Question(Tech Question) Liftedpsd 2003-2007 6.0L Power Stroke 7 09-16-2007 03:35 PM
Boost question, maybe MAP sensor question 6_Myles 1994-2003 7.3L Power Stroke 5 10-28-2006 12:42 AM
Edge Juice Question Question Jaadc01 General Ford Truck and Excursion 6 05-23-2006 12:40 PM
