Jacked up fuel pressure/idle - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 99' Dually, this thread has received 2 replies and been viewed 819 times.
post #1 of 3 (permalink) Old 02-25-2010, 01:17 AM Thread Starter
i just installed an ad II about 3 mo ago in the truck in my sig, i have been hearin something in the idle that sounds like its missing or cutting out, sounds like i left my sub bumping and sounds like its slowly getting worse, but the thing i am worried about is my fp, i have my pump set at 15 psi @ idle. it idles normal but when giving it throttle my fp goes up, cruising down the road no matter what speed it will range between 15 and it has hit 32 a few times depending on how much throttle i give her, any ideas?
99' Dually is offline
post #2 of 3 (permalink) Old 02-25-2010, 06:32 PM
IDImonsterstack's Avatar
might have a bad pump call AD and ask them what is up??
under the knife for rebuild
IDImonsterstack is offline
post #3 of 3 (permalink) Old 02-25-2010, 10:09 PM
2nd Gen Guru
Mopar1973Man's Avatar
I would call PureFlow and have it dealt with under warranty...
Mopar1973Man is offline
fuel pressure during idle SparkyLV 5.9L Cummins (1998.5-2002) 35 02-03-2009 09:17 PM
Fuel pressure & overflow valve pressure Deeslfxr 5.9L Cummins (1998.5-2002) 4 01-09-2009 11:35 PM
Is this normal oil pressure at idle? dropped_dually Duramax 2004.5-2005(LLY) 6 12-19-2007 06:42 PM
how much oil pressure at idle when warm? SICKS-O 1994-2003 7.3L Power Stroke 3 06-14-2007 04:15 AM
Setting fuel pressure regulator w/out a fuel pressure gauge hhrecovery 2003-2007 6.0L Power Stroke 17 04-02-2007 02:25 PM
