SMOG!!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by IDImonsterstack, this thread has received 6 replies and been viewed 1196 times.
post #1 of 7 (permalink) Old 02-26-2010, 05:35 AM Thread Starter
IDImonsterstack's Avatar
SMOG!!!
hey guys F**K california this place blows goat balls!! i just opend my regestration for next year says i have to have the mother F****R smogged pass a evap test and smoke test on dyno. i aint doin nothing they can. anyone else got this smog crap at all???
under the knife for rebuild
IDImonsterstack is offline
post #2 of 7 (permalink) Old 02-26-2010, 06:38 AM
from what I hear it's a idle to 2500 3 times to see for smoke and they to a visual check. just remove your edge and you should be good. yes it sucks but thats what california will always be known for smog tests. it's all about the carb money thats all
01quadcab is offline
post #3 of 7 (permalink) Old 03-02-2010, 01:50 PM
2nd Gen Guru
Mopar1973Man's Avatar
Barrow a smarty and put it at half power...
Mopar1973Man is offline
post #4 of 7 (permalink) Old 03-02-2010, 03:00 PM
they are plugging into the obdII port on the trucks to scan for things like that.
post #5 of 7 (permalink) Old 03-02-2010, 03:20 PM
2nd Gen Guru
Bummer... It was a thought. Then yeah you would have to pull your electronics out...
post #6 of 7 (permalink) Old 03-02-2010, 04:49 PM
PhilipR's Avatar
Could you run some B100 through it for that tank to get the test?
-Phil-
PhilipR is offline
post #7 of 7 (permalink) Old 03-03-2010, 01:38 AM
We have to pass smog here in mass if the truck's GVWR is more than
10,000 LBS. My ford 7.3L powerstroke dump has to pass it. My 01 dodge cummins 2500 don't need to pass emissions.
He has to take the egde out or make sure all your factory wiring is put together right, wrap the edge in black tape, and anyhthing inside like the attitude I would just hide under the dash, or just dispay your digital guages only and keep the edge off. You just really need to make sure that all your factry wiring is together so it don't throw codes and don't forget to erase your codes before you go in. Take it for a highway beat run and clear out the extra soot built in the exhaust. Other than that you should be fine. They can't tell you what you should and shouldn't have in the truck, As long as there is no codes, and passes the puff and sniff test you should be good. Play dumb with them if they ask anything about the stuff in the truck.
cumminsdude2001 is offline
help petition the new CA smog law nevrenufhp Southwest 0 02-06-2010 02:45 PM
smog check spock Southwest 0 01-15-2010 03:50 PM
Smog Pump stone821 7.3L and 6.9 IDI (Pre 1994) 2 03-06-2009 06:33 PM
SCT and Smog Mustang42 2003-2007 6.0L Power Stroke 11 12-16-2005 09:13 PM
smog test ?? DieselDadio 1994-2003 7.3L Power Stroke 5 08-16-2005 03:13 PM
