Wheel bearing and other issues - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by smokndiesel7588, this thread has received 3 replies and been viewed 803 times.
post #1 of 4 (permalink) Old 02-26-2010, 05:16 PM Thread Starter
Singles Club #2
smokndiesel7588's Avatar
Well...last saturday I went out for lunch. Ate there, went out, started the truck, went to back out...and no reverse ...put it in neutral and pushed it...so i went to go to the parts store for some snowmobile parts and i then blew the left front wheel bearing.
So i talked to my mechanic and he said i most likely blew out the band for reverse. Guess its time to do my manual conversion (and luckily I found a 6 speed and all the parts for the conversion) so at the end of March..bye bye auto...bring in the manual
and oh..anybody have any advice on pullin off the wheel bearing? I know its pretty straight forward, but if theres any tricks or tips, they'd be great to know.
Greg
smokndiesel7588 is offline
post #2 of 4 (permalink) Old 02-27-2010, 02:37 AM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Use a socket as leverage but nudge the wheel. Dont put too much pressure if you do more then likely it'll blow a seal.But i used a big hammer,wedge,and a deep socket (i think) if not a reg socket will get-r done. and the new one went right in. Before you put the new one in get some fine grit sandpaper and sand it alittle. Mine actually came out in 2 peices and all the bearings just fell out Thats what i wanted to do to my 12v but couldnt find any haha
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
The Following User Says Thank You to 97CumminsTurboDiesel For this addition to TDG:
smokndiesel7588 (02-27-2010)
post #3 of 4 (permalink) Old 03-01-2010, 07:25 PM Thread Starter
Singles Club #2
got the wheel bearing out and replaced on saturday...i talked to a couple people and they said to make it easy, take the 4 bolts out halfway, then take a socket and short extension and put it on the bolts. Then have a second person there to watch that as you turn the wheel, the socket and extension hit up against the part of the axle that the knuckle connects to. I did the bottom right and the top left bolts and the hub assembly popped right out.
Greg
post #4 of 4 (permalink) Old 03-01-2010, 08:52 PM
Keep that little secret to yourself. If someone has to do their you can help them and charge alittle haha One of my buddy's hes a darn good mechanic and never thought of that idea so he beated and banged for 8hours and finally got it out.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
wheel bearing again....... Dodge-Power 5.9L Cummins 12 Valve (1994-1998.5) 3 09-28-2009 01:32 AM
Wheel bearing? Jeffybuilt 5.9L Cummins (1998.5-2002) 12 09-17-2009 09:58 PM
wheel bearing issues? Dodge-Power 5.9L Cummins 12 Valve (1994-1998.5) 3 06-13-2009 09:27 PM
wheel bearing cookiemonsterblue 5.9L Cummins 12 Valve (1994-1998.5) 10 05-04-2007 06:09 PM
Wheel bearing? bigdiesel502 1994-2003 7.3L Power Stroke 25 07-03-2006 04:39 PM
