questions about 24 valve.. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by southern-stroke, this thread has received 6 replies and been viewed 1141 times.
post #1 of 7 (permalink) Old 03-01-2010, 10:18 PM Thread Starter
southern-stroke
southern-stroke's Avatar
Send a message via MSN to southern-stroke
i've almost decided to get a 24 valve instead of a common rail because it will be cheaper, and i will have more money for upgrades. So; how good are these motors? Some people tell me they're just as good as better than a common rail, and same say their a POS. Whats some commons problems with these? Also, how much HP does a regular 24 valve have? How about a HO? What all can be done to these? And this truck will be a manual, I've decided 2500 at most for a double disc clutch is cheaper than 6000 for a built auto... Give me some input, any and all is apreciated..
''Can You Keep Up?'' while I'm ''In The Passing Lane!''
southern-stroke is offline
post #2 of 7 (permalink) Old 03-01-2010, 11:34 PM
Singles Club #2
smokndiesel7588's Avatar
some common problems are fuel pressure problems, and when the fuel pressure drops it can cause the injection pump to fail...so you'll want to put a fuel pressure gauge on it to make sure you have at least 10 psi feeding the injection pump....the SO motor puts out i think 185hp in the late 90s models and 235hp in 01 and 02..the HO's were 245hp.
as far as mods..you can do the basic exhaust, intake, turbo upgrade, chip/programmer, injectors, cam and then you can go further and pull the VP44 and put in a p-pump and that way you would have the mechanical injection pump
what DD clutch were you looking at?
Greg
smokndiesel7588 is offline
post #3 of 7 (permalink) Old 03-02-2010, 02:06 AM Thread Starter
southern-stroke
i'm lookin at a south bend. the have a lifetime warranty, and everyone who pulls around here uses em. they've never had to replace theirs yet, with the exception of my buddy who's replaced 3 in 6 months. but that's because all he does is give his 9 kinds. if you p-pump a 24 valve, can you still use chips/programmers on them? sorry, i'm a powerstroke and 6.5 guy lol...
post #4 of 7 (permalink) Old 03-02-2010, 03:27 AM
Like smokin says the first thing is put a fuel gauge in it and monitor fuel psi. I keep mine at 15 psi. What are you looking to get out of it? If it's a daily driver or high horse power. You can make upwards of 600-700 hp with the vp44 pump with the right mods. Mine has a Fass oem replacement pump which mounts on the side of the block under the filter housing. They run about 30% over stock which is enough if your just going to run a programer, exhaust small stuff like that. If your looking for high horsepower then go with the 150/180 Fass pump instead. I run a Edge, 4" exhaust w/o muffler just a cat, an OFE South Bend clutch. It's my work truck with snow plow and all of that fun stuff but it has 321,000 miles on it with the original vp44 pump.
I have a shop and I've replaced 3 vp44 pumps on customers pickups in the last 6 months all due to low fuel psi.
Any common rails you look at make sure you check starting when it's cold. I've also had several of these come in with hard starting due to low fuel psi to the injectors. Which can be injectors or the jumper tubes.
95 F350 crew, 6.0 intercooler, GTP38R, 4" downpipe w/5" exhaust straight pipe, 250cc injectors, DP Tuner w/Live tune, A1000 fuel pump, Terminator Dual HPOP, A1-H11 head studs, rewired the EBV for exhaust brake, 6" lift, rear shackle flip with air bags and traction bars, 35" Cooper STT's, ZF6 spd and South Bend dual disk clutch.
KSEnt is offline
post #5 of 7 (permalink) Old 03-02-2010, 03:45 AM
TDG Mafia Goon
BombDocDiesel's Avatar
I have my mods to my 24-valve listed, as well as my last run on the dyno. They are great motors and a little PM goes a long way.
As others have stated, a lift pump and gauges are a must.
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
post #6 of 7 (permalink) Old 03-02-2010, 04:31 AM
Singles Club #2
If you ppump the 24 valve, it eliminates the ability to use chips/programmers.
I'm currently working on getting everything set up to do a conversion to a NV5600 since my tranny's about smoked. My mechanic recommended the SB Street Dual Disk for my application since I don't plan on doing any sled pulling until I get out of college and have the money to fix the stuff I'll break
Greg
post #7 of 7 (permalink) Old 03-02-2010, 01:34 PM
2nd Gen Guru
Mopar1973Man's Avatar
Lets say I've got 2 member on my site that are.... 2001 Dodge Cummins with 800K miles and still going... Then 1992 Dodge Cummins with 623K miles and still going...
CR engine weak spot is the injectors when they wear out it cost much more for six injectors on CR engine than a VP44...
Fuel pumps and plumbing... Keep your fuel pressure above 10 PSI (I'm starting to suggest above 14 PSI for long life).
235/460
How about a HO?
245/505
Lots and lots... Fueling Boxes, programmer stacks, injectors, high idle mod, crankcase vent mod, etc...
Input in blue...
Mopar1973Man is offline
looking at 97 12 valve, have questions. GM Guy 5.9L Cummins 12 Valve (1994-1998.5) 4 01-15-2010 06:27 AM
24 Valve 98-02 Valve Cover TLadd Whats Been Sold 2 04-17-2009 02:38 PM
Air shutoff valve and 3 way fuel valve '05Supersmoker Sled Pulling 2 02-04-2008 11:23 PM
cummins 60 lbs valve springs 12 valve imported_machine2 Whats Been Sold 0 05-07-2007 11:58 PM
1998 24-valve compared to 12-valve Michael 5.9L Cummins (1998.5-2002) 1 06-28-2006 04:22 PM
