HD headlight harness - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by lbdodge24v, this thread has received 4 replies and been viewed 728 times.
post #1 of 5 (permalink) Old 03-03-2010, 01:17 AM Thread Starter
lbdodge24v's Avatar
Is anyone using one of these harnesses?
I decided to get one from LMC and am wondering if I made the right choice. After installing it how I think it should go, I turned on the lights and everything seemed to work fine. I waited till dark and took it out for a test drive, and the lights appear brighter for the short ride I took. But, while driving I flipped on the brights, and they are alot better, but when going back to dim, the brights stay on, the dims and fogs also come on when going back to dim. Here is where I can't figure it out, if I turn off my fog lights everything works fine, but when the fog lights are on, the lights will not come off bright, when I put them on dim everything comes on. I still have the stock style bulbs and headlights, and this is the harness I got http://www.lmctruck.com/icatalog/de/full.aspx?Page=46
Has anyone else had this problem or have any suggestions?
Thanks for any and all help
02 Dodge Ram CTD, 6 spd., HMR Street Drag Clutch, Raptor 150, Edge Drag Comp, Smarty, Injectors, aFe air intake, 2 in leveling kit, 4 in exhaust, and 3 guages-Fuel Pressure, Boost, and EGT's.
The Toy a Jummins!!
lbdodge24v is offline
post #2 of 5 (permalink) Old 03-03-2010, 01:09 PM
2nd Gen Guru
Mopar1973Man's Avatar
Bad ground... Or did the relay stick or something?
Mopar1973Man is offline
post #3 of 5 (permalink) Old 03-03-2010, 03:36 PM Thread Starter
lbdodge24v's Avatar
It works fine when the fog lights are off, but when the fog lights are on the brights will not turn off. I hooked the ground back to the battery, thought that would be the best. But everything works perfect with the fog lights off, but when they are on the brights will not go off after turning them on.
The Toy a Jummins!!
post #4 of 5 (permalink) Old 03-03-2010, 05:06 PM
2nd Gen Guru
Sounds like a mis-wired setup... Fog lamps shouldn't effect it...
post #5 of 5 (permalink) Old 03-03-2010, 05:24 PM Thread Starter
lbdodge24v's Avatar
I wouldn't have thought the fog lights would bother it either, o well. May go back to my stock stuff, it works lol. Till I can figure this out.
The Toy a Jummins!!
Headlight and Harness Ford Configurator dfuser Supporting Vendors Forum 1 03-03-2008 09:55 PM
Headlight harness Super04Duty General Ford Truck and Excursion 1 08-21-2007 12:26 AM
Headlight harness racehauler Supporting Vendors Forum 3 04-27-2007 06:54 PM
GOS headlight harness upgrade hhrecovery General Ford Truck and Excursion 8 01-15-2007 01:42 AM
Headlight harness from G.O.S. BAF250 2003-2007 6.0L Power Stroke 5 07-13-2006 01:58 AM
