code help!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dodgedisorder, this thread has received 4 replies and been viewed 731 times.
post #1 of 5 (permalink) Old 03-03-2010, 04:18 AM Thread Starter
ricer's suck!
code help!!
hey guys I have a few codes i need help on how to fix them, my truck will NOT boost more than 22 psi at wot and with my smarty stacked with a van aaken box, it still defuels itself
p0122 throttle position sensor V too low
p0602 ecm fueling calibration error
and the other day i had one about the map sensor but that didnt show up tonite
is it as easy as replacing sensors, or do i have a goofy pump or computer?
2000 Dodge Ram CTD 2500, P-Pumped 180hp, ddp 150's, s300, nice camshaft, fass 150, CAT filters, full 6speed conversion all the way to the dana 80 w/ disc brakes, zoom ceramic clutch
388hp/ 959ftlbs
soon to come;
progressive nitrous, latter bars
dodgedisorder is offline
post #2 of 5 (permalink) Old 03-03-2010, 05:03 AM
Singles Club #2
smokndiesel7588's Avatar
the p0602 is there because of your smarty...the truck will throw that code when any fueling box is detected...as for the TPS...its not seeing the voltage it wants to see..hopefully someone else will chime in as to what may be causing the low voltage
Greg
smokndiesel7588 is offline
post #3 of 5 (permalink) Old 03-03-2010, 05:44 AM Thread Starter
ricer's suck!
Cool thanks man, the thing bugs me is that I know I should be running more than 35psi with my set up, both of my boxes should stop the ECM from defueling.
What are guys thoughts on that?
388hp/ 959ftlbs
soon to come;
post #4 of 5 (permalink) Old 03-03-2010, 01:12 PM
2nd Gen Guru
Mopar1973Man's Avatar
For the P0122 code...
http://mopar.mopar1973man.com/tips/c...apps-codes.htm
APPS sensor could be the cause of the boost problem too... (Limp Mode)
Mopar1973Man is offline
post #5 of 5 (permalink) Old 03-03-2010, 05:06 PM Thread Starter
ricer's suck!
cool thanks, i'll definitely check my stuff and let you know what i do to it
388hp/ 959ftlbs
soon to come;
Can I Put J-Code Exhaust Manifolds On a C-Code Engine JLanzino 6.2L Diesel Engine 6 10-08-2009 02:29 AM
code kc04 6.7L Cummins (2007.5-2011) 3 04-19-2009 03:38 PM
P1689 ERROR CODE - Cause of code Found! Mopar1973Man 5.9L Cummins (1998.5-2002) 6 02-02-2009 02:36 PM
icp code sidssm 1994-2003 7.3L Power Stroke 1 11-18-2007 06:54 PM
DT With eng code axle Medium and Heavy Duty 5 07-07-2007 11:22 AM
