boost elbow - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by duallycummings01, this thread has received 16 replies and been viewed 4304 times.
post #1 of 17 (permalink) Old 03-03-2010, 09:16 PM Thread Starter
Cool boost elbow
I have a 2001 cummings and was looking at some earlier post of the boost elbow and dont make sense of where it goes . Does any body have a video on this couldnt get the old post to open up. And is it worth it? Also i have edge with att. fass fuel 150 setting on edge is 5x5 and tranny is been set up to handle it.
duallycummings01 is offline
post #2 of 17 (permalink) Old 03-03-2010, 10:17 PM
IDImonsterstack's Avatar
if you have the factory turbo with an automatic you cannot use a boost elbow since the wastegate tube is built into the houseing that turbo is the hy35 if oyu have a hx35 off of a stick truck then you can use it. the little roundthing on the turbo closest to the motor thats the wastgate that line that goins into the compressor housing theres a fitting there, unskrew the old one and skrew the new one in and have fun. they are worth it to me i have one on mine before i would hit 23psi and ok powerthen i put the elbow on now im hitting 35psi and she screams
under the knife for rebuild
IDImonsterstack is offline
The Following User Says Thank You to IDImonsterstack For this addition to TDG:
duallycummings01 (03-04-2010)
post #3 of 17 (permalink) Old 03-04-2010, 12:07 AM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
The edge should have came with one.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #4 of 17 (permalink) Old 03-04-2010, 01:40 AM Thread Starter
i got the truck with the edge in it. any pics?
post #5 of 17 (permalink) Old 03-04-2010, 02:17 PM
Ol ok, its right above the bottom intercooler line and theres a rubber hose connected to it. But if its a automatic your gonna have to have a J-hook and the boost elbow wont work on it.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #6 of 17 (permalink) Old 03-04-2010, 05:13 PM
Official TDG Doctor
hccumminssmoke's Avatar
You have 3 options:
1. Bully Dog J-Hook
2. Do a Turnbuckle Mod
3. Get a real turbo
Nate
hccumminssmoke is offline
The Following User Says Thank You to hccumminssmoke For this addition to TDG:
duallycummings01 (03-06-2010)
post #7 of 17 (permalink) Old 03-06-2010, 12:06 AM
I take a order with #3 and make that a large.Haha
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #8 of 17 (permalink) Old 03-06-2010, 01:33 AM Thread Starter
i went with #2 for now. hey 30lbs is better than 21 lol.
post #9 of 17 (permalink) Old 03-06-2010, 01:49 AM
Official TDG Doctor
sure is, and for pocket change its worth it imo
Nate
post #10 of 17 (permalink) Old 03-06-2010, 02:02 PM
2nd Gen Guru
Mopar1973Man's Avatar
Another option is buy someones used HX35 turbo when they upgrade to something bigger...
Mopar1973Man is offline
Boost elbow Carbur8tr 5.9L Cummins (1998.5-2002) 3 11-16-2009 03:32 AM
installing boost elbow thats not a elbow Sabbath5.9 5.9L Cummins 12 Valve (1994-1998.5) 6 07-08-2009 06:00 PM
Boost elbow kc04 5.9L Cummins (2003-2007.5) 4 01-13-2008 11:26 PM
boost elbow? cummins kid 5.9L Cummins 12 Valve (1994-1998.5) 9 11-26-2007 03:07 AM
boost elbow crf450 2003-2007 6.0L Power Stroke 5 08-16-2007 03:21 AM
