47RE Transmission problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ron nekula, this thread has received 3 replies and been viewed 6360 times.
post #1 of 4 (permalink) Old 03-05-2010, 03:14 PM Thread Starter
I need some help. I have a 99 Dodge 3500 dually with the 24 valve 5.9 TD. I just had my 47RE tansmission completely rebuilt. I picked the truck up and it drove great. after about an hour of highway driving, I got back into town and starting noticing the truck didn't have any power. I discovered that it was starting in second gear. After I let it sit and cool a bit, it seem to start off in 1st again. Once it warmed up, it was starting in 2nd gear. So.... took it back and the shop has been looking at it for over a week now and can figure out why this is happening. At this point after replacing all the electronics internally and replacing the valve body, they are saying it is the transmission computer. This computer runs $630. I am hoping I can find someone else that might have some knowledge on this problem. Help? Anyone. Options on the transmission computer?
Thanks,
Ron
ron nekula is offline
post #2 of 4 (permalink) Old 03-06-2010, 02:46 AM
Thanks,
Ron
Might be some kind of seal. If it is fine whn it is cold sounds like its when the fluid is thick enought it can't get to where ever it is going. Once the fluid warms up its thin enough to try and leak to somewhere its not suppose to. Make sure they put all 3 ring seals on the input shaft, I would also have them rip it apart and put all brand new seals again. I would do that before I spend big money on a PCM. If the tranny was fine before it needed a rebuild then I doubt it is the PCM that needs to be replaced.
cumminsdude2001 is offline
post #3 of 4 (permalink) Old 03-06-2010, 12:33 PM Thread Starter
Found the problem
Thanks for your reply. After further research, I realized that the computer could not cause this problem. I had heard that a cracked valve body could cause this. Although they had changed this twice, it might not had been possible to see anything when it was out to be inspected because it was not hot and under torque. So, I asked them to try another one that had already been tested. Problem solved! Hope this knowledge it useful for someone out there.
Ron
post #4 of 4 (permalink) Old 03-06-2010, 02:12 PM
its more than likley your 1-2 shift solinoid mine did the same thing after rebuild. Save some $ in the long run put the 3-4 and govener pressure soilind in at the same time casue they dont last much longer. at least mine didnt
2013 Ram 3500 Crew 6.7L 6x6 auto
11 Chevy 1500 ext 4x4 5.3L
07 3500 Crew 6x6 6.7L 6spd manual Edge Juice w/attitude, banks ram air box, 4'' exhaust, egr delete, south bend dual disk, boss 9' 2'' power v
Dads Ride 04 3500 Crew 4x4 5.9L Auto Larime 5'' exhaust, air bags
Bros ride 04 3500 Crew 6x6 5.9L Auto Stock
00 3500 Ext cab Dually 3.55 gears, 4'' MBRP, K&N, edge juice w/ attitude, rev maxx stage 4 converter, custom built tranny, Air Dog 150
98 3500 Ext cab Dually 3.55 gears handshaker, 4 into 5 exhust, edge juice w/att, BHAF
86 k2500 5.7 gas 3.73 gears, lock right front, warns,(My Hunting Beater)
King is offline
1997 Dodge 47RE transmission ash_flat_diesel Whats Been Sold 1 03-09-2008 12:00 AM
47RE transmission gon2sea 5.9L Cummins (1998.5-2002) 9 01-31-2008 02:31 AM
47re transmission dodge22racing 5.9L Cummins 12 Valve (1994-1998.5) 1 01-02-2007 04:45 PM
47RE Transmission hotforddiesel Whats Been Sold 5 10-26-2006 04:17 PM
