TRANSGO shift kits? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hin0031, this thread has received 3 replies and been viewed 729 times.
post #1 of 4 (permalink) Old 03-06-2010, 03:50 PM Thread Starter
TRANSGO shift kits?
How are these products? Anyone used them? How are they to install?are they worth the money?
hin0031 is offline
post #2 of 4 (permalink) Old 03-06-2010, 06:58 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Ive usually B&W shift kits in my drag truck but usually just drain the pan and take off the valve body and insert the heavier springs and so on. Bascally the only thing your doin is putting more pressure on the tranny and tranny lines so for example leave it like the way it is and the tranny is gonna slip and all else and if you insert the shift kit it wont slip and the higher RPM and speed is the tighter the bands/clutches get. What do you have done to your truck now and is your truck slipping? Usally you can get a good torque converter and valve body and thats all yourll need, if you dont go too crazy with it
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #3 of 4 (permalink) Old 03-08-2010, 05:17 AM
Ghost
Phily's Avatar
I like Superior's shift kits. Lower price, and I've had better luck with superior over transgo. Last transgo I did, something went wrong, or I messed something up, or something bizarre happened.
Phily is offline
post #4 of 4 (permalink) Old 03-09-2010, 04:16 AM
get the stage II kit. lots of trans places just use that for their valvebody upgrade.
dieselautopower is offline
transgo shift kit ? hotshot4819 2003-2007 6.0L Power Stroke 4 04-14-2008 01:27 AM
transgo shift kit! brentos Whats Been Sold 0 01-16-2008 07:34 PM
transgo jr shift kit bigcountry GM Transmissions 4 12-13-2007 05:41 PM
Transgo shift kit imported_99powerstroke Whats Been Sold 13 09-25-2007 02:29 PM
Transgo Shift kit for LB7 tahoedmax GM Transmissions 9 08-28-2007 05:10 PM
