RPMs ???? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JUMPSTER93, this thread has received 12 replies and been viewed 1706 times.
post #1 of 13 (permalink) Old 03-06-2010, 11:16 PM Thread Starter
RPMs ????
Just bought a 99 Ram 3500, and had a question about the RPMs. The truck is a six speed with the 12 valve and runs 2000 rpms at 60 mph. Is this normal operating range? I don't want to push it too hard. My '06 F250 runs 70 mph at 1800 rpms.
I know that this truck has a brand new 6 speed in it because I know the previous owner. I just hope they put the right one in it. Any help would be appreciated. Thanks.
JUMPSTER93 is offline
post #2 of 13 (permalink) Old 03-07-2010, 01:18 AM
2nd Gen Guru
Mopar1973Man's Avatar
Sound like a 4.11 rear end...
As for pushing it.. I just got back from a trip... I was pushing for time more than MPG's set the cruise for 80 MPH on the Interstate and was twisting 2200 RPM's for over 60 miles.
Mopar1973Man is offline
post #3 of 13 (permalink) Old 03-07-2010, 12:53 PM
cowboytw13's Avatar
[QUOTE=Mopar1973Man;961688]Sound like a 4.11 rear end...
I have the 4.11's and that sounds about right. It won't hurt the truck to run that hard, it just sucks when it comes to fuel economy I'm running about 16-17ish, and it's loud as hell. The only thing you can do is get taller gears, or something like a gear vendor aux. transmission. Also, I don't think there is a difference between the overdrive gears from a 5-6 speed, just an extra gear in between.
cowboytw13 is offline
post #4 of 13 (permalink) Old 03-07-2010, 03:03 PM Thread Starter
[quote=cowboytw13;961851]
I feel like I need another 2 gears...
post #5 of 13 (permalink) Old 03-07-2010, 03:19 PM Thread Starter
What gauges do you think I should put on this truck. I know fuel pressure, pyrometer, and boost. But anything else? Remember it is a 6 speed, I don't even know if you can put a trans temp gauge on it.
Thanks
post #6 of 13 (permalink) Old 03-08-2010, 02:44 AM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Thanks
Naw i wouldnt worry about it, But thats what i would go for is a pyro,boost, and fuel pressure. If your still running the stock lift pump (which runs off the cam), your gonna have to get a isolator to keep the gauge from jumping if not itll kill the gauge. But if you have a aftermarket fuel system like a Fass or a Airdog. Your fine. Its not a ness. thing to have a fuel pressure gauge like it is on a 24valve but it does help diagnose the probem.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #7 of 13 (permalink) Old 03-09-2010, 02:20 PM
2nd Gen Guru
You'd be surprised how many problems can be diagnosed between the information on your gauges and the information given by error codes...
post #8 of 13 (permalink) Old 03-09-2010, 04:14 PM
PhilipR's Avatar
If it's a '99 it should have the 24V......not a 12V.
-Phil-
PhilipR is offline
post #9 of 13 (permalink) Old 03-09-2010, 04:57 PM Thread Starter
My mistake, it does have the 24 valve.
Anybody know where I can get a set of 3.55 rear gears? I am going to be driving this truck about 150 miles a day and need to be able to go 70 mph and not at 2500 rpms.
post #10 of 13 (permalink) Old 03-09-2010, 05:04 PM
Local junkyard maybe, just tear it apart and clean it real good and inspect.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
14,000 rpms blackcloudCTD95 The Parking Lot 2 02-24-2010 11:11 PM
holding rpms 2004 Psd 2003-2007 6.0L Power Stroke 5 10-28-2009 01:35 AM
Rpms RHCDIESEL 2011+ 6.7L Power Stroke Diesel 13 06-23-2009 02:40 AM
4.10 or 4.30 rpms? snoboy 2003-2007 6.0L Power Stroke 20 08-07-2007 03:45 AM
More RPMS WBV06CTD 5.9L Cummins (1998.5-2002) 10 11-05-2006 10:24 PM
