different injector pump question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hawkeye213, this thread has received 2 replies and been viewed 793 times.
post #1 of 3 (permalink) Old 03-08-2010, 06:01 AM Thread Starter
hawkeye213's Avatar
My friend has 2002 dodge 2500 6 speed 140,000 miles completely stock. On the way to work injector pump went out. After work I pulled him home. He had the truck running on the way home just had in neutral for the power steering and and brakes. Its about 10 miles home. About halfway home all his dash gauges just start going crazy all the way up and then back down to zero. He flashed his lights I pulll over and we checked under the hood but everything was fine. It wasn't hot or anything. Anybody have a clue why his gauges would act like this. We replaced this injector pump about a year and half ago. He swears his gauges went crazy like this when the IP went out last time. Yes we went back with standard lift pump and should have gone with one of the after market ones. He is ordering another IP and a fass LP, and a fuel pressure gauge and we will try it again. But was just wondering why the gauges would go nuts like that ?
Thanks Rob
BHAF
ISSO gauges
Live simply so that others may simply live
hawkeye213 is offline
post #2 of 3 (permalink) Old 03-09-2010, 12:02 AM
not sure that its VP44 related. I have never had a customer mention a gauge problem when they needed a new VP44
dieselautopower is offline
post #3 of 3 (permalink) Old 03-09-2010, 02:17 PM
2nd Gen Guru
Mopar1973Man's Avatar
Sounds like a CCD network fault more than anything...
Here read up...
http://mopar.mopar1973man.com/tips/c...al/ccd/ccd.htm
Mopar1973Man is offline
p pump 24 valve injector question smokin24valve 24 Valve Performance 3 10-11-2009 04:24 AM
I need an injector pump and a lift pump for a 98.5 24valve CRAZY ROB Whats Been Sold 7 07-01-2009 11:15 PM
Injector Pump and Lift Pump are toast. Now What? 6thFrame 5.9L Cummins (1998.5-2002) 21 05-19-2009 09:32 PM
Question on Fuel Injector Pump, 99 Dodge 24 valve farriersam 24 Valve Performance 2 08-29-2007 10:23 PM
1994 7.3L injector pump question Charlied1 7.3L and 6.9 IDI (Pre 1994) 6 06-22-2007 08:36 PM
