2002 dodge 2500 5.9 cummins running poorly - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by budman2002, this thread has received 11 replies and been viewed 10886 times.
post #1 of 12 (permalink) Old 03-08-2010, 08:41 PM Thread Starter
budman2002
Unhappy 2002 dodge 2500 5.9 cummins running poorly
My 2002 dodge truck began to get some wierd symptoms. Water in fuel light on, check engine light on, temp gauge going up and back down, fuel pedal loss of accelleration and no power. The engine will start and idle but the pedal is dead when trying to rev the engine. The transfer pump was reeplaced due to finding some aluminum flakes in the filter and the tank. No sign of water and the light is still on. What is happening? Has anyone had this situation happen or heard of anything so bizzarre? HELP!
budman2002 is offline
post #2 of 12 (permalink) Old 03-08-2010, 10:51 PM
whats your fuel pressure at? could be apps
01quadcab is offline
post #3 of 12 (permalink) Old 03-08-2010, 11:56 PM
JDolezal's Avatar
Hate to say it but i've had all of those symptoms....bad ECM. Thats what happened to our 02 anyhow
91.5 Dodge 250, rclb, 4x4, Getrag, little extra fuel and timing, straight pipe
94 Dodge 2500, rclb, 4x4, NV4500, little extra fuel and timing, straight pipe
95 Dodge 2500, rclb, 4x4, auto, gasser.
02 Dodge 2500, rclb, 4x4, NV4500, Edge EZ, straight pipe
JDolezal is offline
post #4 of 12 (permalink) Old 03-09-2010, 01:08 AM
Mine did the same thing and the ecm was bad.
hin0031 is offline
post #5 of 12 (permalink) Old 03-09-2010, 02:12 AM
Yep, I'm right with these guys. That sounds like an ECM issue for sure.
post #6 of 12 (permalink) Old 03-09-2010, 11:27 AM
bmoeller's Avatar
"Obama = Hoax and Chains"
bmoeller is offline
budman2002 (03-14-2010)
post #7 of 12 (permalink) Old 03-09-2010, 02:15 PM
2nd Gen Guru
Mopar1973Man's Avatar
Check for error codes I bet you got a bunch of high volt sensor codes (IAT, MAP, APPS, etc) and then you might find a P0606 (ECM Failure)
Yeah I got a truck down the road from me with the same issues...
x3 Yeap its a bad ECM...
Mopar1973Man is offline
The Following User Says Thank You to Mopar1973Man For this addition to TDG:
post #8 of 12 (permalink) Old 03-10-2010, 07:47 PM Thread Starter
budman2002
Bad ECM
As luck would have it.... Thanks for the info. all. I have the truck at the dealer to decipher the codes I couldn't read but all things point to the #@%#[email protected]# thing, I guess.... :-( Are the modules readily repairable???? I talked with the Cummins folks and they want $3,000.00 for the one for my serial number engine. Moving forward is going to be painful.
post #9 of 12 (permalink) Old 03-10-2010, 08:17 PM
2nd Gen Guru
I've seen rebuilder shops for much cheaper. Send it in and they rebuild it, reflash it, and send it back...
post #10 of 12 (permalink) Old 03-11-2010, 01:14 AM
I had mine rebuilt. cost about 500. can also buy remans on the internet as well. turned out very well.
hin0031 is offline
The Following User Says Thank You to hin0031 For this addition to TDG:
running poorly when tuned jeffro22 2003-2007 6.0 Tuner Forum 4 04-29-2009 09:29 PM
2002 Dodge Ram 2500 4x4 Lifted! Cheap! Nice! NCcummins Whats Been Sold 8 12-31-2008 04:07 PM
2002 Dodge Ram 2500 NCcummins 5.9L Cummins (1998.5-2002) 2 12-24-2008 03:03 AM
Help with problem (no codes) but running poorly ict03x 2003-2007 6.0L Power Stroke 2 04-01-2008 05:12 AM
2002 Dodge Cummins 2500 4x4 parttimepuller Whats Been Sold 0 10-23-2007 05:34 PM
