edge - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by King, this thread has received 5 replies and been viewed 732 times.
post #1 of 6 (permalink) Old 03-10-2010, 03:19 AM Thread Starter
edge
if i wanted to could i stack another programer over the edge juice?
2013 Ram 3500 Crew 6.7L 6x6 auto
11 Chevy 1500 ext 4x4 5.3L
07 3500 Crew 6x6 6.7L 6spd manual Edge Juice w/attitude, banks ram air box, 4'' exhaust, egr delete, south bend dual disk, boss 9' 2'' power v
Dads Ride 04 3500 Crew 4x4 5.9L Auto Larime 5'' exhaust, air bags
Bros ride 04 3500 Crew 6x6 5.9L Auto Stock
00 3500 Ext cab Dually 3.55 gears, 4'' MBRP, K&N, edge juice w/ attitude, rev maxx stage 4 converter, custom built tranny, Air Dog 150
98 3500 Ext cab Dually 3.55 gears handshaker, 4 into 5 exhust, edge juice w/att, BHAF
86 k2500 5.7 gas 3.73 gears, lock right front, warns,(My Hunting Beater)
King is offline
post #2 of 6 (permalink) Old 03-10-2010, 01:09 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
i wouldnt suggest it just because itll add too much timeing and fuel.And more then likely whatever you stack it with and the edge wont go in the MAP sensor, but i could be wrong. But thats what i did tho wheni got my edge stack it with a BD plug & power chip. and the throttle wouldnt go over 2000RPM, no pedal and etc.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #3 of 6 (permalink) Old 03-10-2010, 03:01 PM
2nd Gen Guru
Mopar1973Man's Avatar
You could run a Smarty... but MUST run NON-TIMING software only... But you'll find out that it will beat the crap out of the trans in the low end and the up end will be short.
The best stack I know of is the TST and Smarty because TST is a fuel only box and the Smarty provides the timing together its a mean pair...
Mopar1973Man is offline
post #4 of 6 (permalink) Old 03-10-2010, 09:45 PM
I thought that the Smarty added fuel too also with the timeing?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #5 of 6 (permalink) Old 03-10-2010, 09:48 PM
2nd Gen Guru
Odd programs are fuel & timing...
Even programs are fuel only....
The Following User Says Thank You to Mopar1973Man For this addition to TDG:
97CumminsTurboDiesel (03-10-2010)
post #6 of 6 (permalink) Old 03-10-2010, 09:51 PM
You learn somethang new everyday!
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
PPE, Edge Juice, Edge EZ Jonathanrayce Whats Been Sold 2 03-11-2009 02:10 AM
edge comp or edge juice w/attidue fitz1985 5.9L Cummins (1998.5-2002) 13 10-03-2007 01:43 AM
EDGE EZ vs. EDGE COMP hccumminssmoke 5.9L Cummins (1998.5-2002) 7 03-27-2007 04:07 PM
Edge Drag Comp vs. Edge Juice/Attitude lbdodge24v 5.9L Cummins (1998.5-2002) 12 03-08-2007 08:31 PM
edge juice and edge comp??? masonjo 24 Valve Performance 19 01-23-2007 11:51 PM
