more rpm's - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 9512valve, this thread has received 10 replies and been viewed 1163 times.
post #1 of 11 (permalink) Old 03-11-2010, 12:03 AM Thread Starter
Diesel Outlaw
9512valve's Avatar
more rpm's
ok my buddy has a 24v and wants to know is there a chip out there where he can get 3k or 4k out of it?
dont remember
9512valve is offline
post #2 of 11 (permalink) Old 03-11-2010, 12:27 AM
2nd Gen Guru
Mopar1973Man's Avatar
You better build the engine up with the proper stuff before you worry about increasing redline...
But after you've done the major investing to your engine there is...
http://www.bluechipdiesel.com/redlinebox.html
Mopar1973Man is offline
post #3 of 11 (permalink) Old 03-11-2010, 02:26 PM Thread Starter
Diesel Outlaw
9512valve's Avatar
what has to be done to the 24v's for them to handle this?
dont remember
post #4 of 11 (permalink) Old 03-11-2010, 02:56 PM
2nd Gen Guru
Basically full rebuild but balance everything that spins.
Basically anything that spins need to be balanced and have tight bearings to keep it from flying apart. If you ever pick up a crank for a Cummins you'd relize there is huge amount of weight spinning around inside the block.
Then all the valve springs have to be beefed up to keep from floating valves into a piston. So while your at it you might as well fire ring or o-ring the head, port and polish, etc...
So when you get right down to it this is a expensive thought just to gain a few extra RPM's...
post #5 of 11 (permalink) Old 03-12-2010, 11:26 AM
I am running a 01 with a comp box and I can turn 3K without defueling. You might check into a TST box I think they will let you turn up the redline.
openrange is offline
post #6 of 11 (permalink) Old 03-12-2010, 03:13 PM
The edge drag comp will add rpm also. There are a lot of people out running stock motors with just hp upgrades running 4k rpm with no issues. I am one of them. but anything more than about 4k and your asking for issues.
01quadcab is offline
post #7 of 11 (permalink) Old 03-13-2010, 03:23 PM
I turn 3300 RPM on a completely stock bottom end and valve train. If I were going to step up to near the 4k mark, I would invest in some better push rods and valve springs. The cam and bottom end should be fine IMO.
post #8 of 11 (permalink) Old 03-14-2010, 06:44 AM Thread Starter
Diesel Outlaw
9512valve's Avatar
i know he has a edge juice with attitude i believe and injectors, he is talking about getting a smarty i really have no knowledge on the 24v im a 12v guy. just trying to get info before he throws money away. this truck will be mostly street occasion pulls and will tow. he wants bd twins i believe towing twins and a hot rod pump, im trying to talk him out of the bd twins i can build a twin set up a lot cheaper and a lot better for what he wants. its an 01 with a 6 speed
dont remember
post #9 of 11 (permalink) Old 03-14-2010, 06:45 AM Thread Starter
Diesel Outlaw
9512valve's Avatar
also he has the hot unlock
dont remember
post #10 of 11 (permalink) Old 03-14-2010, 04:17 PM
With the hot unlock on the juice it should fuel to 3200 and not backdown till 4k. He needs to go in and check his max rpm set point to make sure it's not set to something lower. I have not stacked, or plan on stacking a smarty with my setup because you loose hp and top end with them which in turn gives slower 1/4 times and thats what I do with mine. For what he wants the smarty might help and should give him some bottom end.
The Following User Says Thank You to 01quadcab For this addition to TDG:
9512valve (03-14-2010)
rpm's ???????????? imported_coalfed 5.9L Cummins (2003-2007.5) 1 08-04-2007 11:39 PM
How many rpm's? 2006f250bob 2003-2007 6.0L Power Stroke 3 11-15-2006 08:16 PM
TC Lock-up MPH or RPM's? DesertSands 2003-2007 6.0L Power Stroke 1 05-22-2006 06:40 PM
RPM's PSmokinD 1994-2003 7.3L Power Stroke 1 03-06-2006 05:42 PM
RPM's in tach 1,000 low powerstrokeit 2003-2007 6.0L Power Stroke 11 12-20-2005 12:58 PM
