Suggestion for Mods - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by smknf250, this thread has received 8 replies and been viewed 978 times.
post #1 of 9 (permalink) Old 03-11-2010, 04:20 AM Thread Starter
Suggestion for Mods
My dad just bought a really clean well maintained 2001 Dodge 3500 Cummins with a 6 speed. The truck is bone stock and just turned 200,000 miles. My dad doesn't need a ton of power but loves to tinker....what would you guys suggest for a mild chip, exhaust, intake, stuff like that (without messing with the clutch)....not that familar with the cummins on mods. Thanks for the advice.
Please keep in mind that he is 62 years old. Lay off the nitrous
smknf250 is offline
post #2 of 9 (permalink) Old 03-11-2010, 11:34 AM
FASS lift pump, 4 inch turbo back exhaust, afe or k&n filter, quadzilla mileage max with xzt towing package. Check ebay for most and will find it pretty reasonable.
hin0031 is offline
post #3 of 9 (permalink) Old 03-11-2010, 02:03 PM Thread Starter
The fass lift pump. I have been reading alot about that the lift pumps on these trucks have problem...Can you explain what this does? Power? Reliablity? Also how are is the install? Thanks.
smknf250 is offline
post #4 of 9 (permalink) Old 03-11-2010, 02:10 PM
FASS will handle mods, more reliable, and guaruntied!!! They don't fail, install is easy, and if it should fail it is covered by one hell of a warranty. Don't waste anytime! get the OEM lift pump out ASAP. they fail constantly, and if you don't catch it right away, it will take inj. pump with it. Also a fuel pressure gauge is a must.
hin0031 is offline
post #5 of 9 (permalink) Old 03-11-2010, 05:18 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Get a Fass or a Airdog like already suggest. I was gonna say if hes easy with the clutch go with a Edge comp box and get a fuel pressure, EGT, and boost gauge! and get a 4'' exgaust back and get like a S&B air box. But if hes not lookin to spend that much money i got a BD chip if hes interested in it.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #6 of 9 (permalink) Old 03-11-2010, 10:21 PM
edge ez full set of gauges including a fuel pressure gauge and a cold air intake. 4" turbo back exhaust. Depending on how well maintenance was done have valves adjusted and retorque the head bolts. Also a good idea to do all the fluids in the truck too diffs, trans motor etc.
01quadcab is offline
post #7 of 9 (permalink) Old 03-12-2010, 01:02 AM
I've heard that your not surpose to re-torque the head
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #8 of 9 (permalink) Old 03-12-2010, 01:51 AM
so just let the bolts back off the whole time?
post #9 of 9 (permalink) Old 03-13-2010, 03:31 PM
Ghost
Phily's Avatar
The NV5600 OEM clutch doesn't last long with moderate power increases. Anything aftermarket does better, but OEM sucks. A mild chip, intake and exhaust, while pulling a load could be enough to make the clutch go south.
Now if the clutch is a decent aftermarket clutch. You'll be fine with any moderate power increase.
Phily is offline
Just a suggestion Harley6.4 2008-2010 6.4L Power Stroke 12 05-15-2009 07:47 PM
Got a suggestion racehauler Site Information 2 11-28-2007 03:41 AM
suggestion BogginF350 Site Information 3 10-18-2006 01:40 AM
