aaps sensor - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hawkeye213, this thread has received 5 replies and been viewed 3687 times.
post #1 of 6 (permalink) Old 03-11-2010, 06:57 AM Thread Starter
hawkeye213's Avatar
aaps sensor
Ok just got back from my buddies house installed new IP and lift pump started it up and it ran just like it did before. It Idles fine but when you give it the gas it just runs rough. No accelleration or power. The cruise control light blinks on and off randomly and the temp gauge goes crazy. I mentioned this in an earlier post. Anyway we pulled the codes. I know we should have done that first (long story). These are the codes we got.
PCU p0122, p0500, p1693.
ECU p0121, p0230, p1689, p0217, p1488, p0575, p0562, po237.
Not sure what to do next. From looking up the codes could be Apps or ecm. Any other suggestions or thoughts would really be appreciated. I actually have the same truck 2002 6 speed HO stock except mine is 4wd and his 2wd. Would it be advisable to put my APPS sensor on his truck just to see if it made a difference. I don't mind doing it to help him out but after seeing how much they cost (595.00) just don't want to screw mine up. Any help would be greatly appreciated. I feel bad for him cause he just laid out 1500.00 for the IP and LP and his truck is still messed up.
Thanks for your help in advance
Rob
BHAF
ISSO gauges
Live simply so that others may simply live
hawkeye213 is offline
post #2 of 6 (permalink) Old 03-11-2010, 02:06 PM
P0121-ACCELERATOR PEDAL POSITION SENSOR VOLTS DO NOT AGREE W/IDLE VALID SIGNAL
POSSIBLE CAUSES
5 Volt supply circuit shorted to voltage with ignition ON
APP sensor
IVS # 2 circuit shorted to voltage
Sensor ground circuit open
5 volt supply circuit shorted to voltage with the engine running
ECM
P0122-ACCELERATOR PEDAL POSITION SENSOR SIGNAL VOLTAGE TOO LOW
POSSIBLE CAUSES
5 Volt supply at APPS shorted to ECM sensor ground
APPS signal circuit shorted to ECM sensor ground
5 volt supply to ground
APPS signal circuit shorted to ground
APPS signal circuit open to ECM
PCM (APPS) short to ecm sensor ground
ECM (APPS) to PCM (APPS) circuit shorted
ECM (APPS) to PCM (APPS) circuit open
Short to ECM sensor ground.
Accelerator Pedal Position Sensor (APPS)
Engine control module
Powertrain control module
P0217-DECREASED ENGINE PERFORMANCE DUE TO ENGINE OVERHEAT CONDITION
POSSIBLE CAUSES
ECT sensor
P0237-MAP SENSOR VOLTAGE TOO LOW
POSSIBLE CAUSES
Other DTC'S
Checking boost pressure sensor
Checking the 5-volt supply circuit
MAP signal circuit short to ground
MAP signal circuit short to sensor ground
MAP sensor
Intermittent wiring problem
ECM
P0562-BATTERY VOLTAGE LOW
POSSIBLE CAUSES
LOW BATTERY VOLTAGE
P0562-CHARGING SYSTEM VOLTAGE TOO LOW
POSSIBLE CAUSES
Checking for PCM codes
ECM
Fused B+ circuit open
Ground circuit open
High battery cable resistance
Low battery current
Low battery voltage
P0575-CRUISE CONTROL SWITCH VOLTAGE LOW
POSSIBLE CAUSES
S/C wiring harness observable problem
S/C switch (ON/OFF)
Clockspring shorted to ground
S/C switch (resume/accel)
S/C switch signal circuit shorted to ground
S/C signal circuit shorted to sensor ground
ECM
P1488-AUXILIARY 5 VOLT OUTPUT TOO LOW
POSSIBLE CAUSES
MAP Sensor
CMP sensor
Oil pressure sending unit
Water in fuel sensor
5-volt supply circuit shorted to ground
5-volt supply circuit open
Broken, bent or pushed out terminals
ECM
P1689-NO COMMUNICATION BETWEEN ECM AND INJECTION PUMP MODULE (OBDII)
POSSIBLE CAUSES
Wiring and connectors
Fuel injection pump relay output circuit open
Ground circuit open or high resistance
Datalink (+) circuit open
Datalink (+) circuit shorted to ground
Datalink (-) open
Datalink (-) shorted to ground
ECM
P1693-DTC DETECTED IN PCM
POSSIBLE CAUSES
DTC detected in the PCM
First if you have mods, remove, clear codes and run. if they go away, put mods back on one by one and see if any set the codes off. The bad thing here is when mine did it it was a bad ECM, and every symptom leads to a bad ECM. I have seen it work to clear codes. So try this first, but I would have to say it sounds like a bad computer. They can be rebuilt or buy a reman.
hin0031 is offline
The Following User Says Thank You to hin0031 For this addition to TDG:
hawkeye213 (03-12-2010)
post #3 of 6 (permalink) Old 03-12-2010, 04:16 AM Thread Starter
hawkeye213's Avatar
Thanks Hin
Sorry so late getting back. BUSY!!! Anyway he ordered an apps sensor from Mopars source timbomb I think. But will get onto checking the computer. I think I saw on mopars or somwhere in all my searches about testing the apps sensor. Will look for that. Is there away to check the computer for good or bad ? On the codes. His truck is completely stock. Is there away to clear the codes and start over ? When you get a code when you fix the problem is it erased or does it stay ? Sorry that sounds dumb but was just wondering how that works.
Thanks Rob
BHAF
ISSO gauges
post #4 of 6 (permalink) Old 03-12-2010, 07:43 PM
It will not go away right away. It may take a few cycles, but unfortunatly it will effect the way it runs. check out bule chip diesel for the apps. it is way cheaper and way better.
hin0031 is offline
hawkeye213 (03-15-2010)
post #5 of 6 (permalink) Old 03-14-2010, 01:19 AM
2nd Gen Guru
Mopar1973Man's Avatar
Don't bother with the APPS... Look at you codes... You got a mess of low volt codes that are not making sense...
ECM is on the way out... I've seen this before...
Mopar1973Man is offline
The Following User Says Thank You to Mopar1973Man For this addition to TDG:
post #6 of 6 (permalink) Old 03-15-2010, 06:26 PM Thread Starter
hawkeye213's Avatar
Thanks to both of you for your replies. While I am sure this is not what he wants to hear at least we are getting closer to getting it fixed. Next question I guess is where the best place to get a replacement ecm at a good price ?
Thank you Rob
BHAF
ISSO gauges
What is this sensor just visiting 1994-2003 7.3L Power Stroke 22 11-21-2010 03:25 AM
Cat 3116e: Fuel Temp Sensor & Boost Pressure Sensor probablecause Medium and Heavy Duty 0 02-03-2009 01:54 AM
map sensor outlaw1_gt 5.9L Cummins (1998.5-2002) 3 01-30-2009 01:57 PM
icp sensor taco_style 2003-2007 6.0L Power Stroke 9 09-21-2007 01:01 AM
MAP sensor ? racehauler 1994-2003 7.3L Power Stroke 15 02-20-2007 10:37 PM
