2001 RAM2500 engine oil system ?'s - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by M123KT-450, this thread has received 9 replies and been viewed 1071 times.
post #1 of 10 (permalink) Old 03-12-2010, 01:11 AM Thread Starter
M123KT-450's Avatar
What would be the best way to flush the engine oil system in a 24V-CTD ?
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
1971 AMC /Jeep J4K-DRW.
1988 AMC /Jeep Comanche.
1991 Dodge RamCharger.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
M123KT-450 is offline
post #2 of 10 (permalink) Old 03-13-2010, 12:52 PM
bmoeller's Avatar
Hydrotex Lubriclean.
"Obama = Hoax and Chains"
bmoeller is offline
M123KT-450 (03-14-2010)
post #3 of 10 (permalink) Old 03-14-2010, 01:24 AM
2nd Gen Guru
Mopar1973Man's Avatar
Ummmm.... May I ask why you do something like this?
Mopar1973Man is offline
post #4 of 10 (permalink) Old 03-14-2010, 01:37 AM
ADMIN/MAFIA
neeltburn's Avatar
I would wonder why this would need to be done? You have details mike?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #5 of 10 (permalink) Old 03-14-2010, 03:17 AM
2nd Gen Guru
Scratch my head...
I've got a Frantz Filter on my truck as a bypass filter filtering down to 1/2 Micron... Run Chevron Delo 15W-40
I've also go a member that has NOT changed oil in over 70K miles now using a Motorguard Bypass filter and WalMart Universal 15W-40 engine oil and doing oil testing through Blackstone Labs...
Then I've got 2 members on my site that run standard ol' Chevron Delo or Retella 15W-40 oil for over 600K (1992 Cummins) and 800K miles (2001 Cummins)..
So why the flush?
post #6 of 10 (permalink) Old 03-14-2010, 11:55 PM Thread Starter
M123KT-450's Avatar
Where dose one get such a product ?
Engine looked horribly dirty inside compared to other diesels i have owned , before i go pouring in my High dollar oil and want it cleaned out, and all leaks found and repaired . . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #7 of 10 (permalink) Old 03-15-2010, 12:06 AM
Any time I want to flush a system and when I am going to remove an oil pan, or do major work I add a quart of ATF, or two. Use the vehicle for over 50 miles then drain. On class eights I add a gallon, ATF dexron #3 works for me, then I blow in shop air into the oil galley either threw the oil preasure gage hose or the compucheck fitting. Works for me, and ATF is nearly pure detergent, and still a good oil, I overfill it and do not race it or load it heavy.
Johnp3 is offline
post #8 of 10 (permalink) Old 03-15-2010, 04:16 AM Thread Starter
M123KT-450's Avatar
I done that in the past . . . I may do it again . . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #9 of 10 (permalink) Old 03-15-2010, 04:28 AM
AMSOIL engine flush.
01quadcab is offline
post #10 of 10 (permalink) Old 03-15-2010, 04:40 AM Thread Starter
M123KT-450's Avatar
AMSOIL flush ?
I used it twice in the past I got better results with ATF !
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
2001 RAM2500 steering issues ! ?'s M123KT-450 5.9L Cummins (1998.5-2002) 41 04-08-2010 06:09 AM
2001 RAM2500 again more ?'s . . . M123KT-450 5.9L Cummins (1998.5-2002) 17 03-02-2010 01:51 AM
2001 Ram2500 Power/Performance Mods. M123KT-450 5.9L Cummins (1998.5-2002) 16 12-15-2009 03:57 AM
2001 engine parts jmul 5.9L Cummins (1998.5-2002) 4 06-30-2007 02:49 AM
2001 Cummins engine question... Morse 5.9L Cummins (1998.5-2002) 10 05-02-2006 01:19 PM
