Bad Injection Pump? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Hotrodx199, this thread has received 2 replies and been viewed 1324 times.
post #1 of 3 (permalink) Old 03-15-2010, 10:06 PM Thread Starter
Bad Injection Pump?
Our 01 cummins is gone now, but before we got rid of it, it would spit out white smoke and make all sorts of popping sounds. It started that it just "ran out of fuel" probably from a clogged fuel filter. Then we drove it home and it died again. 3rd time it started spitting out white smoke and popping.
The funny thing is that, when it's started up first thing in the morning and cold, you can firewall the engine and it will run just fune, no white smoke or popping. When it's at operating temperature, it will start spitting out white smoke and pop like crazy.
Even though our truck is gone now, i just figured i would post so i could learn something new lol.
Hotrodx199 is offline
post #2 of 3 (permalink) Old 03-17-2010, 12:40 AM
2nd Gen Guru
Mopar1973Man's Avatar
You need to check 2 things...
1. Fuel pressure
2. Error Codes
The fuel pressure is critical to the life of a VP44 pump being it the only thing that cools and lubes the pump internal parts and the electronics of the pump. Then the error codes would of told you if the pump was bad. But I know if there is white smoke there is 2 problems occuring.
1. Lack of timing (fully retarded) Typically has P0216 error code.
2. Lack of fuel pressure to fire correctly.
But since you dont have the truck any long its really hard to teach with out a good example present...
Mopar1973Man is offline
post #3 of 3 (permalink) Old 03-21-2010, 03:06 AM
Yeah that vp was probably dead pretty much.
Wesley B is offline
I need an injection pump and an aftermarket lift pump for my 98.5 24v CRAZY ROB Dodge parts wanted 2 02-10-2010 06:35 PM
injection pump help imported_diesel71 Duramax 2006-2007(LBZ & LLY) 1 09-24-2007 10:51 PM
looking for 98 injection pump Wild Wills Whats Been Sold 1 07-02-2007 05:07 AM
injection pump ? smokeisfun 5.9L Cummins 12 Valve (1994-1998.5) 5 12-16-2006 10:29 PM
Injection pump diesel_ram_man 12 Valve Performance 2 12-02-2006 09:52 PM
