HX35W what will it hold - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by IDImonsterstack, this thread has received 23 replies and been viewed 1883 times.
post #1 of 24 (permalink) Old 03-16-2010, 02:38 AM Thread Starter
IDImonsterstack's Avatar
ive got everything in my sig plkus 100hp injectors will the hx35w hold up to this amount of power and for how long lmao just want some opinions
under the knife for rebuild
IDImonsterstack is offline
post #2 of 24 (permalink) Old 03-16-2010, 01:32 PM
It can hold up for a little while but your drive pressure is through the roof and your egt's are probably hot. I would save up for a new turbo asap so just drive by your egt gauge and even if you get a small 62 your truck will run 10 times better than with that hx 35.
dbeach is offline
post #3 of 24 (permalink) Old 03-16-2010, 04:58 PM
SSpeeDEMONSS's Avatar
they can hold up pretty well. i would drill out the wastegate port and drill thru the divider as well. i think i went 7/8" on mine.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #4 of 24 (permalink) Old 03-16-2010, 06:29 PM
Official TDG Doctor
hccumminssmoke's Avatar
you should be fine, just watch your egt's, boost, try to refrain from barking it a lot...
Nate
hccumminssmoke is offline
post #5 of 24 (permalink) Old 03-17-2010, 12:21 AM Thread Starter
what do you mean drill out the wastegate port and the divider? will the bad drive pressure blow a head gasket?also if i stay lowon the chip and not like 5x5 all the time i should be ok casue i normally only drive on level 1&2 some times 5 just to race onto the freeway lol
post #6 of 24 (permalink) Old 03-18-2010, 05:40 PM
What are sparkplugs
ICEMAN3005's Avatar
If you look at my sig mine would have held up ok but lots of throttle destroyed it. So the moral of the story keep EGT's low and boost pressure below 35. Mine blew about 45 PSI, EGT's were over 1200 if I remember correctly.
2002 dodge 2500 4x4
Edge Juice W/Attitude
Hot Rod VP-44 stage 2
200 H.P. Injectors
HX-40 turbo(Silencer Ring MIA)/ BHAF
FASS 150/150
billet trans/TC 1600 stall (rebuilt myself) parts supplied by DUNERITETORQUECONVERTERS
2" leveling front kit
TRUCK SOLD
Two 84 chevy 1 1/2 ton pickups 6.2L Diesel (stock)
Turbo400, NP208 transfer case, Dana 60 front, GM 14 bolt rear W/Locker
89 Chevy K-5 Blazer 350/700r4/np241/gm10bolt rear dana44 front
ICEMAN3005 is offline
post #7 of 24 (permalink) Old 03-19-2010, 07:18 AM Thread Starter
k thanks yeah ive hit 32 without the injectors so i think im gonna set the wastegate a like 34 just to be safe. i was wanting to get and hx40 but coulndt afford it right now so i jsut rebuilt this one in an hour and gonna run it till i can get a bigger turbo.im thinkin hx40 should hold up. another thing the T3 gasket on mine broke and no one has them and dealer wants $39 for one damn gasket can i just clean the the turbo and motor side and mate them and not have any issuses??
post #8 of 24 (permalink) Old 03-19-2010, 03:51 PM
if you pull the turbo, pull the back plate off. you will see the wastegate puck in there. unhook the actuator from the arm and the wastegate will flip up and out of the way. i think its around a 5/8 hole. take a larger bit, like 7/8" and drill out the hole and also drill thru the divider so that both sides get wastegated.
they can take a lot of abuse.
post #9 of 24 (permalink) Old 03-19-2010, 05:35 PM
anything over 35psi is just hot air. I know a few people that have blown theirs up with a max of 42 psi. They will not take daily abuse of 40 psi but will hold up ok now and then.
01quadcab is offline
post #10 of 24 (permalink) Old 03-19-2010, 05:39 PM
yeah, that pic was when my wastegate was still plugged(bought it that way). its nowhere near that with the 18.5cm housing now.
will it hold? FF4431 12 Valve Performance 5 09-28-2007 02:52 PM
Hx35w 12cm wastgated $300 plus shipping SPLnut Whats Been Sold 1 07-24-2007 06:20 PM
Diesels on hold? Rutcutter 2008-2010 6.4L Power Stroke 9 02-05-2007 07:28 PM
How Much Will It Hold JoshesRam 5.9L Cummins 12 Valve (1994-1998.5) 4 07-02-2006 03:01 AM
think you can hold on to a..... Deezle1 Road Kill, Bench Racing 17 03-05-2006 08:10 PM
