injector pump install? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminsracer2010, this thread has received 7 replies and been viewed 1899 times.
post #1 of 8 (permalink) Old 03-17-2010, 12:34 AM Thread Starter
Question injector pump install?
hey guys i havent been on in a while, . but heres the issue at hand.
i know i have to replace my injector pump, ( 02 5.9 ) can anyone tell me how to do this, ? any help is appreciated,
cumminsracer2010 is offline
post #2 of 8 (permalink) Old 03-17-2010, 12:35 AM
2nd Gen Guru
Mopar1973Man's Avatar
It really easy... I got a few handy write ups for this process...
Pump...
http://mopar.mopar1973man.com/tips/c...44-replace.htm
Injection lines...
http://mopar.mopar1973man.com/tips/c...tion-lines.htm
Reprime...
http://mopar.mopar1973man.com/tips/c...prime-fuel.htm
Mopar1973Man is offline
post #3 of 8 (permalink) Old 03-17-2010, 12:38 AM Thread Starter
thanks much, im mostly not sure how to retime it? you still got ur webpage?
post #4 of 8 (permalink) Old 03-17-2010, 12:47 AM
2nd Gen Guru
No timing to worry about place the key in the shaft (arrow pointing towards the pump) and add a drop of super glue to it so it don't fall out. Install pump and tight it up... All electronically timed!
Yes my web page is still there... Going to be updated soon...
post #5 of 8 (permalink) Old 03-17-2010, 12:52 AM Thread Starter
thanks again, that helps alot. big fan of ur page btw, i started running the two stroke oil i learned about on ur site, i saw the power gain a little , im not even sure y my pump is goin out. im only at 180000 miles,
post #6 of 8 (permalink) Old 03-17-2010, 06:49 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
could be not enough fuel pressure or a bad lift pump. I suggest when you get that new pump in, install a fuel pressure gauge and check your lift pump too!
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
The Following User Says Thank You to 97CumminsTurboDiesel For this addition to TDG:
Mopar1973Man (03-17-2010)
post #7 of 8 (permalink) Old 03-18-2010, 02:14 AM Thread Starter
i got a fuel presure guage on the truck mounted just before the fuel filter housing , split goin to the housing and injector pump, it reads about 15 all the time? is this right
post #8 of 8 (permalink) Old 03-18-2010, 02:44 AM
2nd Gen Guru
No... Suppose to be after the filter housing ...
Injector install MOPSD250 2003-2007 6.0L Power Stroke 12 09-18-2009 02:53 PM
I need an injector pump and a lift pump for a 98.5 24valve CRAZY ROB Whats Been Sold 7 07-01-2009 11:15 PM
Injector Pump and Lift Pump are toast. Now What? 6thFrame 5.9L Cummins (1998.5-2002) 21 05-19-2009 09:32 PM
Injector pump install iwannagofast 5.9L Cummins (1998.5-2002) 16 01-29-2008 11:02 AM
Injector install Morpheus cycles 2003-2007 6.0L Power Stroke 8 04-04-2006 03:56 AM
