01 cummins - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by [email protected], this thread has received 9 replies and been viewed 1369 times.
post #1 of 10 (permalink) Old 03-20-2010, 02:45 AM Thread Starter
01 cummins
can you set a truck up to pull & drag with? if so, whats the best way?
post #2 of 10 (permalink) Old 03-20-2010, 04:15 AM
Ghost
Phily's Avatar
Engine:
Monsterous turbos, p7100, draft intake, even tube headers, fire rings, studs, injectors,
Transmission:
fully built 47re, billits shafts all around
T-case:
OEM
Rear Dif:
full dana 80 37 spline 1541 shafts conversion w/arb and cover girdle
Front dif:
35 spline chrom moly, ox, u joints.
Tires:
Big.
Phily is offline
The Following User Says Thank You to Phily For this addition to TDG:
[email protected] (03-26-2010)
post #3 of 10 (permalink) Old 03-23-2010, 04:44 PM
2nd Gen Guru
Mopar1973Man's Avatar
Going to need some deep pockets...
Mopar1973Man is offline
post #4 of 10 (permalink) Old 03-23-2010, 05:10 PM
Official TDG Doctor
hccumminssmoke's Avatar
VERY VERY deep pockets, even if you do a lot of the work yourself
Nate
hccumminssmoke is offline
post #5 of 10 (permalink) Old 03-23-2010, 07:06 PM
2nd Gen Guru
Just the P pump conversion could be close to $4,000...
I bet you spend more on the mods than you do for the truck...
post #6 of 10 (permalink) Old 03-24-2010, 02:28 PM
Official TDG Doctor
eaisly, got a good friend of mine, paid 8k for a 99 truck with a "bad vp" turns out it needed a new fuel filter...stealerships anyway, dang near spent more then that on an AT$$$$ tranny...total to about 23k truck and parts...and still isnt that competitive
Nate
post #7 of 10 (permalink) Old 03-25-2010, 03:37 AM
I would cry if that happened to me
Carbur8tr is offline
post #8 of 10 (permalink) Old 03-25-2010, 04:18 AM
2nd Gen Guru
I'm going to be smart and not even try...
But I got to admit that would suck to have that all happen...
post #9 of 10 (permalink) Old 03-27-2010, 03:03 PM
p7100's Avatar
Send a message via AIM to p7100
none
dont forget traction bars and a good fuel system....
1996 CTD ex cab LB, 5 speed 4x4, LUK clutch, 370"s, fully built and bench flowed pump from TRE Diesel, timing at 17*, airdog 150, aem brute force intake pullin air through a schwitzer 65mm charger, and pushin it out a FBD 5 inch exhaust painted flat black, 6 in. MBRP tip
Waitin for install, ARP studs, 4 GSK, and added timing
p7100 is offline
post #10 of 10 (permalink) Old 03-27-2010, 03:11 PM
2nd Gen Guru
The problem is when you increasing the HP/TQ of a truck that mean everything down stream must increase in ability to hold this new found power. Other than that the first run will show you your weakest link quickly! Hence why you going to need deep pockets...
Basic downhill effect.
Engine Upgrade -> Transmission Upgrade -> Transfer Upgrades -> Driveshaft Upgrades -> Axle Upgrades
Then is some of the stock stuff hold up rather well and other stuff is rather weak for just stock power.
cat or cummins cat power Diesel Conversion 18 02-22-2009 04:54 PM
cat or cummins cat power The Polling Place 13 02-12-2009 05:21 AM
Cummins Conversion Adapter 460 to cummins Dieselwrencher Diesel Conversion 0 05-23-2007 05:29 AM
Cummins Conversion Adapter 460 to cummins Dieselwrencher Whats Been Sold 0 05-23-2007 05:29 AM
350 Cummins? ocmechanx Medium and Heavy Duty 2 03-30-2006 04:38 PM
