How much is too much fuel pressure? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by chevy, this thread has received 5 replies and been viewed 3477 times.
post #1 of 6 (permalink) Old 03-21-2010, 05:22 PM Thread Starter
I have my Raptor set for 20 at idle and it stays around 15 when I punch it. Is that okay, or do I need to lower it some?
1999 Dodge 3500 Dually, Cummins, Edge Juice with Attitude, BHAF, open exhaust, Auto tranny, 21 MPG and it pulls a giant camper pretty well at 11 MPG. Just added the Raptor 150 Pump and big line kit.
chevy is offline
post #2 of 6 (permalink) Old 03-22-2010, 04:52 AM
that should be fine.
01quadcab is offline
post #3 of 6 (permalink) Old 03-22-2010, 12:21 PM
Official TDG Doctor
hccumminssmoke's Avatar
I've been idleing at 25 for a long time, WOT around 20/21
Nate
hccumminssmoke is offline
post #4 of 6 (permalink) Old 03-23-2010, 01:03 AM
IDImonsterstack's Avatar
idle on mine is 24 and WOT is 14
under the knife for rebuild
IDImonsterstack is offline
post #5 of 6 (permalink) Old 03-23-2010, 12:03 PM
bmoeller's Avatar
When you break it, then you'll know for sure.
"Obama = Hoax and Chains"
bmoeller is offline
post #6 of 6 (permalink) Old 03-23-2010, 04:26 PM
2nd Gen Guru
Mopar1973Man's Avatar
I know of a couple of guys that installed a mechanical pump from a 12V and getting about 35-40 PSI on the high side. I think this is a bit extreme...
Never heard of a failure yet... But something to consider you flooding the return rail with pressurized fuel from the overflow valve. So being a little over 20 PSI isn't going to hurt nothing but consider the designed pressure and what in might do to the pump later in life.
I'm set for 17.5 at idle but at WOT never get below 15 PSI... Never
Mopar1973Man is offline
Fuel pressure & rail pressure gauges??? SS1156 5.9L Cummins (2003-2007.5) 9 07-23-2009 06:33 PM
Fuel pressure & overflow valve pressure Deeslfxr 5.9L Cummins (1998.5-2002) 4 01-09-2009 11:35 PM
Setting fuel pressure regulator w/out a fuel pressure gauge hhrecovery 2003-2007 6.0L Power Stroke 17 04-02-2007 02:25 PM
Fuel Mods: X-over vs full fuel kit and pressure... bakantor 2003-2007 6.0L Power Stroke 39 03-10-2007 02:06 PM
$100 Off DJ's FUEL+ - Fuel Pressure Intensifier MOMBENZ Supporting Vendors Forum 3 12-13-2006 01:49 AM
