hydro-boost??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by snowman_w900, this thread has received 1 replies and been viewed 1345 times.
post #1 of 2 (permalink) Old 03-22-2010, 03:24 AM Thread Starter
snowman_w900's Avatar
hydro-boost???
yesterday i was coming home, noticed the abs light comes on. drive about 10 more miles, pull in the driveway, shut the truck off, get out and i hear the electric motor on the hydro boost out under the master cylinder running. wouldnt shut off...so...i unplugged it. anyone else had this problem. also, the power steering is starting to give out when it warms up. if ya rev it up, the power steering will work ok, but it aint right. whats the deal. is the hydro boost a dealer item.....any help would be appreciatied fellas.....
snowman_w900 is offline
post #2 of 2 (permalink) Old 03-23-2010, 04:40 PM
2nd Gen Guru
Mopar1973Man's Avatar
Not a hydro booster problem...
It the ABS pump motor. The ABS computer went wild and is running the ABS pump motor. Now you can dis-connect the pump on the side of the ABS computer. Then you will need to order a new ABS computer from the dealer and then have the truck present for a flash to program speed, and a few other parameters to fix this issue...
Mopar1973Man is offline
Hydro Steering assist bigastrk Supporting Vendors Forum 1 01-29-2010 01:08 AM
Hydro locked Help 12valvehaze 5.9L Cummins 12 Valve (1994-1998.5) 32 10-06-2009 01:55 AM
Skyjacker Hydro 7000s FX4DUDE General Ford Truck and Excursion 1 07-05-2007 07:13 PM
hydro booster Diesel Fanatic 5.9L Cummins (1998.5-2002) 4 04-13-2007 02:28 AM
Hydro-seed TooMuchBoost The Parking Lot 1 05-20-2005 08:10 PM
