Fittings - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kc04, this thread has received 1 replies and been viewed 656 times.
post #1 of 2 (permalink) Old 03-24-2010, 11:34 PM Thread Starter
Its Cute Aint it!!
Fittings
Ok guys im fixin to do my own big line kit. Ive got hose left over from raptor. I need to know what size is fitting coming out of the filter housing. I see so many different fittings for injector pump i dont know where to start. What fitting can i get with barb fitting and still have 1/8 for fuel preesure. I think i can live without banjo bolt and would like to have fitting that screws into pump. I went ot vulcan performance and they have a lot of fittings i just dont know what size i need to screw into ip. Who has done this and what seemed to work best.
04 smarty beta 4.4 and mp-8 , superchip stickers on the windows. SOLD
Wifes 04.5 4x4 smarty and dr p box exhaust intake and new rubber 502-1162 as of 12-02-09 With mostly stock tranny. Suncoast converter and valve body.
Dad 08 swb 4x4 h&s 5in turbo back egr block edge hot unlock and crappy clutch
98 12v 5spd 4.10s bhaf, exhaust, fuel plate, 4k gsk, timing, pump mods, and 300s Studs, o-ringed head, 3 piece manifold and 5in KDP tabbed, 60lb springs, titanium keepers
Moms 03 6spd- intake, smarty jr!!
01 reg cab dually 4x4 5spd bhaf raptor 150 and comp box Farmboy 5in 2in steel spacers for the rear with 6 new 305s! injectors on the way!!!!!
kc04 is offline
post #2 of 2 (permalink) Old 03-27-2010, 06:27 AM
Metric Adapter 08JIC X M12.
This 08 JIC steel adapter fits the injection pump inlet port in all 24v engines as well as the fuel filter canister inlet and outlet. Hope it help
1999 Dodge 24V CTD 4x4 dually, nv4500, 152000 miles,dual pillar gauge with boost/EGT in one and with front and rear trans in one gauge oper. by the in pillar switch. BD torque converter and triple disk,TC Lock-Up Switch,MagHytec Transmission Pan, Edge Com, Air-Raid intake system, 5" exhaust system, FASS 95,BD valve body,2" dually spacer with 265/75/16
99CTD is offline
The Following User Says Thank You to 99CTD For this addition to TDG:
kc04 (03-27-2010)
Fittings DevilDocTater Supporting Vendors Forum 8 10-23-2009 06:39 PM
AN Fittings dayusex Supporting Vendors Forum 0 10-03-2009 07:26 PM
fuel fittings ? need help matt6243 2003-2007 6.0L Power Stroke 23 02-11-2009 02:53 PM
Special fittings... Extended Power 2003-2007 6.0L Power Stroke 6 01-30-2007 02:21 PM
AN Fittings TC Dmax The Parking Lot 12 10-03-2005 12:07 AM
