VP install - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kc04, this thread has received 3 replies and been viewed 902 times.
post #1 of 4 (permalink) Old 03-27-2010, 09:50 PM Thread Starter
Its Cute Aint it!!
VP install
Ok guys i got everything off i cant ge the pump to bust loose. I got all 4 nuts off backside of the pump as well as 2 bolts in block. I turned key way tdc and put gear puller on and used small pry bar and got pump loose but just cant seem to get it all the way out. Is there a trick to it? When putting new pump on do i need to line gear tdc with mark on timing cover or can i install new punp with key way at tdc. I got all line off and im putting ddp 75s in as well. Im just dont want to get crazy with it and key way fall into cover.
04 smarty beta 4.4 and mp-8 , superchip stickers on the windows. SOLD
Wifes 04.5 4x4 smarty and dr p box exhaust intake and new rubber 502-1162 as of 12-02-09 With mostly stock tranny. Suncoast converter and valve body.
Dad 08 swb 4x4 h&s 5in turbo back egr block edge hot unlock and crappy clutch
98 12v 5spd 4.10s bhaf, exhaust, fuel plate, 4k gsk, timing, pump mods, and 300s Studs, o-ringed head, 3 piece manifold and 5in KDP tabbed, 60lb springs, titanium keepers
Moms 03 6spd- intake, smarty jr!!
01 reg cab dually 4x4 5spd bhaf raptor 150 and comp box Farmboy 5in 2in steel spacers for the rear with 6 new 305s! injectors on the way!!!!!
kc04 is offline
post #2 of 4 (permalink) Old 03-28-2010, 03:01 AM
2nd Gen Guru
Mopar1973Man's Avatar
Here is how to do the install...
http://mopar.mopar1973man.com/tips/c...44-replace.htm
Sound like you don't have gear puller?
Mopar1973Man is offline
The Following User Says Thank You to Mopar1973Man For this addition to TDG:
kc04 (03-29-2010)
post #3 of 4 (permalink) Old 03-28-2010, 11:14 PM
JLWelding's Avatar
Dont forget to pull bracket off.
JLWelding is offline
The Following User Says Thank You to JLWelding For this addition to TDG:
kc04 (03-29-2010)
post #4 of 4 (permalink) Old 03-29-2010, 08:34 PM Thread Starter
Its Cute Aint it!!
I checked and i got all bolts and nuts off. I just wasnt getting rough enough with it. I didnt want to get crazy with it. I got it off now. Thanks guys.
kc04 is offline
GSK Install cumminsdiesel 12 Valve Performance 24 02-20-2010 01:07 AM
AC install Stircrazy 1994-2003 7.3L Power Stroke 3 07-02-2009 05:57 AM
WW install? 02psd 1994-2003 7.3L Power Stroke 6 05-15-2007 04:26 AM
Help with AFE install Uzi556 General Ford Truck and Excursion 10 10-19-2005 11:01 AM
