oil leak - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 1964reo, this thread has received 5 replies and been viewed 1799 times.
post #1 of 6 (permalink) Old 03-31-2010, 11:21 PM Thread Starter
oil leak
my freand has a5.9 cummins 2001 he has a oil leak by the power steering pump how bad is that to fix
1964reo is offline
post #2 of 6 (permalink) Old 04-01-2010, 11:54 AM
milkin cowboy
MILKINGCOWBOY's Avatar
Send a message via AIM to MILKINGCOWBOY
iF ITS THE FRONT CASE GASKET ITS A BIG PROJECT HALF THE DAMN MOTOR HAS TO COME APART AND FRONT CLIP OF TRUCK.......
2002 3500 6 speed ex. cab 4x4 custom flatbed farm truck 9,120 lbs. light weight ALL WAYS HAULIN HAY, CATTLE OR A-$-$!!!! BHAF,4" OPEN STACKS,EDGE JUICE WITH ATTITUDE, AIR DOG II 100,SOUTH BEND CLUTCH
1982 IH Transtar Eagle 4370 turned up 400 Cummins big cam, straight 6" bull haulers one hell of a
Jake and 13 speed od
White 2-105 tractor with 354 Perkins
White 2-135 tractor with 478 White/Hercules
KEEP ON KEEPIN ON
SUPPORT AMERICAS DAIRY FARMS
http://i17.tinypic.com/4u2drv8.jpg
http://profile.myspace.com/index.cfm...ndid=137814954
MILKINGCOWBOY is offline
post #3 of 6 (permalink) Old 04-01-2010, 01:49 PM
r u sure its not just the breather bottle dripping?
hin0031 is offline
post #4 of 6 (permalink) Old 04-03-2010, 02:32 AM
most likely the vacuum pump. There is a through shaft that runs through the ps pump and then drives the vacuum pump. It is very common for the seal to start leaking. It is a couple hour job to replace it and the lines from the Vacuum pump are kind of a pain to get at.
here is the best seal kit that I know of for it, and what I used on mine. Go under the link that says Seal Kit on the left hand side of the web page.
http://www.fixinrams.com/
You can usually see drops of oil starting to form on the shaft of the vacuum pump if you slide a mirror under it, or look up from underneath the truck.
post #5 of 6 (permalink) Old 04-03-2010, 03:33 AM Thread Starter
this one leeks real bad i runs out
1964reo is offline
post #6 of 6 (permalink) Old 04-03-2010, 03:33 PM
2nd Gen Guru
Mopar1973Man's Avatar
Yeap it sounds like a vacuum pump seal is shot... There is pressurized oil feed into that system.
Because all other leaks are non-pressurized. Like cam cover, pan gasket, etc.
Mopar1973Man is offline
Oil Leak Help mjm 2008-2010 6.4L Power Stroke 28 02-11-2010 12:11 AM
99 f-450 7.3D oil pan leak help! Twin Star Farm 1994-2003 7.3L Power Stroke 2 08-06-2009 10:46 AM
oil leak bdog1234 Medium and Heavy Duty 4 04-20-2009 03:37 PM
oil leak beamwalker 1994-2003 7.3L Power Stroke 0 02-08-2007 12:25 AM
Oil Leak Or Boost Pressure Leak At Hot Side Charge Air Cooler (cac) Duct PSDPlayer 2003-2007 6.0L Power Stroke 2 01-12-2007 04:17 AM
