Need help on hooking up a FASS ASAP! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 97CumminsTurboDiesel, this thread has received 9 replies and been viewed 2244 times.
post #1 of 10 (permalink) Old 04-02-2010, 04:33 AM Thread Starter
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Hooking up a fass system up on a 01' Dodge and i need help with hookin up the lines! Thanks
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #2 of 10 (permalink) Old 04-02-2010, 12:38 PM
Official TDG Doctor
hccumminssmoke's Avatar
What lines do you need to hook up?
Nate
hccumminssmoke is offline
post #3 of 10 (permalink) Old 04-02-2010, 03:03 PM Thread Starter
hoses such as your return line, hose to the pump and etc. but i think i got the return line, the line that goes to the IP. but im suck theres a fitting on the pump that has a ''H'' and im not sure where it goes. and also the reason i was asking the so-called mechanic hooked it up wrong. he didnt install a suction tube and used 3/8th hose for the lines.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #4 of 10 (permalink) Old 04-02-2010, 09:17 PM Thread Starter
Update, i called fass and they said they use 3/8 hose.Theres 2 fitting on the injection pump and the mechanic hooked it up on the back fitting which is closest to the cab. but i was thinking, it looked like it would go into the fitting closest to the front just because it was bigger.and the back fitting would be more of a return line just because it was smaller.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #5 of 10 (permalink) Old 04-03-2010, 03:28 PM
2nd Gen Guru
Mopar1973Man's Avatar
I'm not sure about the H... But the fuel lines are...
1. Suction from the tank
2. Return fuel to the tank (usually in the filler neck)
3. pressure suppy to the VP44.
That's odd that FASS would use 3/8" line when 1/2" is so much better...
But here is the hook up on the VP44...
Here is a AirDog setup... It might help...
http://mopar.mopar1973man.com/person...airdog-150.htm
Mopar1973Man is offline
The Following User Says Thank You to Mopar1973Man For this addition to TDG:
97CumminsTurboDiesel (04-06-2010)
post #6 of 10 (permalink) Old 04-03-2010, 05:23 PM
Sounds like it should be on correct. if you have any problems I can take pics of both mine. The 95/95 with 3/8" lines on my 99. Or the 150 on my 01 with 1/2" lines. I had a big line kit on my 01 already so I just got the fittings that would work with the fass
01quadcab is offline
The Following User Says Thank You to 01quadcab For this addition to TDG:
post #7 of 10 (permalink) Old 04-04-2010, 11:15 PM
Yep, Fass comes with a 3/8 line, I've been meaning to upgrade mine to half inch. If memory serves me correctly, the port marked H that you are talking about is for running a fuel heating system. It isn't too likely that you will need one unless you live somewhere that is super cold. Cold enough to get the fuel to gel in the pump.
The Following User Says Thank You to sstockton For this addition to TDG:
post #8 of 10 (permalink) Old 04-06-2010, 03:25 PM Thread Starter
Im still wanting to upgrade to 1/2hose. and there isn't a suction tube.so im hopen thatll fix some of the fuel milage problems
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #9 of 10 (permalink) Old 04-12-2010, 09:16 AM
bmoeller's Avatar
I im hopen thatll fix some of the fuel milage problems
Not likely.
"Obama = Hoax and Chains"
bmoeller is offline
post #10 of 10 (permalink) Old 04-14-2010, 04:12 AM Thread Starter
What do you mean?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
Truck Hooking fuzzys69 General Ford Truck and Excursion 9 10-29-2009 01:19 AM
Hooking up trucks. Phily The Polling Place 15 05-01-2009 01:43 PM
Trucks Hooking fuzzys69 General Ford Truck and Excursion 9 04-24-2007 05:37 AM
Hooking up LED light to gauge imported_99powerstroke 1994-2003 7.3L Power Stroke 9 12-11-2006 10:47 AM
hooking the chains up to a dodge jaysvt 2003-2007 6.0L Power Stroke 30 11-14-2005 11:04 PM
