Bad oil leak - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by [email protected], this thread has received 6 replies and been viewed 6632 times.
post #1 of 7 (permalink) Old 04-05-2010, 01:12 AM Thread Starter
Bad oil leak
I have an 01 cummins and i have a horrible oil leak. Looks like it's coming from the front of motor behind the overflow tube. Any ideas?!
post #2 of 7 (permalink) Old 04-05-2010, 03:06 AM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
could be the tappet cover.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #3 of 7 (permalink) Old 04-05-2010, 02:34 PM
2nd Gen Guru
Mopar1973Man's Avatar
Tappet cover is possible but typically the vacuum pump seals are the cause... Clean good and let it idle and see where its coming from.
Mopar1973Man is offline
post #4 of 7 (permalink) Old 04-05-2010, 08:11 PM Thread Starter
Ok kl thanks. I'll give it a shot
post #5 of 7 (permalink) Old 04-06-2010, 02:10 AM
Stick a small mirror down below the injection pump, or look up from underneath the truck. Odds are you will see drops on the vacuum pump shaft.
post #6 of 7 (permalink) Old 04-07-2010, 07:14 AM
IDImonsterstack's Avatar
my truck had it bad too for a long time took the overflow bottle off and empty it. plus if you had the truck at a steep angle facing downwords it would pour out
under the knife for rebuild
IDImonsterstack is offline
post #7 of 7 (permalink) Old 04-07-2010, 01:12 PM
2nd Gen Guru
Originally Posted by IDImonsterstack View Post
my truck had it bad too for a long time took the overflow bottle off and empty it. plus if you had the truck at a steep angle facing downwords it would pour out (right into the fan scattering it all over the engine been there done that!)
I got a solution for that one...
http://mopar.mopar1973man.com/person...kcase-vent.htm
http://mopar.mopar1973man.com/person...-09-002-02.htm
http://mopar.mopar1973man.com/person...b-09-02-00.htm
Oil Leak Help mjm 2008-2010 6.4L Power Stroke 28 02-11-2010 12:11 AM
99 f-450 7.3D oil pan leak help! Twin Star Farm 1994-2003 7.3L Power Stroke 2 08-06-2009 10:46 AM
Oil leak BlowinSmoke 5.9L Cummins (Pre 1994) 1 04-26-2009 01:19 AM
oil leak beamwalker 1994-2003 7.3L Power Stroke 0 02-08-2007 12:25 AM
Oil Leak Or Boost Pressure Leak At Hot Side Charge Air Cooler (cac) Duct PSDPlayer 2003-2007 6.0L Power Stroke 2 01-12-2007 04:17 AM
