Full fuel system upgrade, stock turbo? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by yfz450_0569, this thread has received 32 replies and been viewed 2327 times.
post #1 of 33 (permalink) Old 04-08-2010, 04:27 PM Thread Starter
I found a truck with 100+ injectors, upgraded injector pump and lift pump... Will the stock turbo keep it cool enough when cooling, with or without a programmer? Would a programmer on the right settings help keep it under control? The truck is a 6-speed manual and we plan on using it as our back-up truck for towing loads and there will be some heavy loads... not sure if we'll have to get a bigger turbo or not.
Me:
'06 4x4 2500 QCSB 5.9 - 155,000 miles
Dads:
'11 4x4 3500 MC DRW 6.7 - 55,000 miles
'08 4x4 2500 MC SRW 6.7 - 115,000 miles
'09 4x4 3500 CC DRW 6.6 - 118,000 miles
www.maxeytrailers.com
yfz450_0569 is offline
post #2 of 33 (permalink) Old 04-08-2010, 05:17 PM
You can make it work and drive by the pyro. I would get a turbo upgrade once I get the cash to do so. a super b would be a good fit for that.
01quadcab is offline
post #3 of 33 (permalink) Old 04-08-2010, 05:24 PM Thread Starter
Exactly the turbo I was thinking... We are definately hooking up gauges quick and if it's too much of a pain, it will get a bigger turbo or smaller injectors!
Me:
Dads:
post #4 of 33 (permalink) Old 04-09-2010, 02:32 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
first i would try it without a programmer and see how it does, what kinda programmer you had in mind? and does the truck have a upgraded clutch?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #5 of 33 (permalink) Old 04-09-2010, 02:47 PM Thread Starter
It's got an upgraded clutch, and a reman block like 2K miles ago, the guy said it's got an oil leak so gotta wait a bit to get it... I was thinking a Smarty, but I don't know much at all about these model cummins, mostly know the later 5.9s and the 6.7s a bit.
Me:
Dads:
post #6 of 33 (permalink) Old 04-09-2010, 03:22 PM
I dont much about a smarty but i know if you got a edge juice with attiude, it would help ya quite a bit just bc you can set like a turbo cool down timer and set each level such as fueling and etc. Ive pulled bout 6ton with that 01' Cummins in my sig. it was alright, i didnt really have a problem with EGT's
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #7 of 33 (permalink) Old 04-09-2010, 03:26 PM Thread Starter
The turbo cool down timer is definately something I would want! So you can adjust fuel and everything with it? So you could adjust it so it gave it less fuel and made it stay cooler? And the loads we pull are normally at least 20,000 lbs up to 30 and even 35K but might not be towing that heavy with this one usually, it's just a back-up if our other one breaks down or can't take all the loads.
Me:
Dads:
post #8 of 33 (permalink) Old 04-09-2010, 03:40 PM
Gotcha, here is the settings on the edge juice with attitude #0 stock #1 fuel milage #2 tow #3 drive #4 race #5 extreme then also you have you pre-boost setting #1 no fuel #2 slight #3 alittle more #4 fuels to mid-range power #5 fuels all the time. Another thing your gonna have to worry about is boost. Get too much boost and your turbo is gonna be a gernade. but you can drill out the wastegate (if its a HX35 turbo) to help control EGT's and boost levels
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #9 of 33 (permalink) Old 04-09-2010, 03:49 PM Thread Starter
Alright well a Smarty has got 9 different performance levels from 30-170 (on the newer ones at least), with different torque settings, injection timing, and injection duration on these trucks... The Edge definately sounds like it's got it's advantages (especially the gauges) though too although I almost do prefer a programmer over a plug-in module.
Me:
Dads:
post #10 of 33 (permalink) Old 04-09-2010, 03:55 PM
True, also too except the turbo timer you have engine protection like its 10 degrees outside and you put on the engine protection itll deufel until the motor gets up to operating temp. then itll go to the level you had it on. Ive also heard too the juice with attitude aint good with a upgraded turbo just because your using the MAP sensor and the map sensor triggers to the ECU over 40psi of boost.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
Fuel system upgrade ? nastyp-stroke1288 2003-2007 6.0L Power Stroke 39 02-25-2009 11:02 PM
fuel system upgrade SOOTBANDIT Supporting Vendors Forum 2 02-25-2009 03:57 PM
stock turbo upgrade bootcamp 2003-2007 6.0L Power Stroke 3 02-10-2009 01:13 PM
Fuel System Upgrade FLCummins24V 5.9L Cummins (2003-2007.5) 4 10-11-2007 05:37 PM
Fuel system upgrade FSD 2003-2007 6.0L Power Stroke 52 10-30-2006 02:57 PM
