Nozzles - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kc04, this thread has received 2 replies and been viewed 1037 times.
post #1 of 3 (permalink) Old 04-09-2010, 01:22 AM Thread Starter
Its Cute Aint it!!
Nozzles
Ok guys got my truck back together with new ip. In the process of being tore down i got som 1.6s from flux there like 90hp. I got truck up and running now o got a ruff idle its kinda lopey. At any rpm its smooth as silk. Not hazy or nothing. Has anybody noticed this. I started taking them out tonight gonna take them tomorow to get pop tested. Does this sound normal. I double checked keyway in pump gear. I took it by local performance shop and they told me its because i didnt get them pop test and pressures are off on them. Is this right. I also did big line kit and i can get it to quit leaking. Its leaking from fitting in ip. The paper said no teflon on it but looks like i might have to!
04 smarty beta 4.4 and mp-8 , superchip stickers on the windows. SOLD
Wifes 04.5 4x4 smarty and dr p box exhaust intake and new rubber 502-1162 as of 12-02-09 With mostly stock tranny. Suncoast converter and valve body.
Dad 08 swb 4x4 h&s 5in turbo back egr block edge hot unlock and crappy clutch
98 12v 5spd 4.10s bhaf, exhaust, fuel plate, 4k gsk, timing, pump mods, and 300s Studs, o-ringed head, 3 piece manifold and 5in KDP tabbed, 60lb springs, titanium keepers
Moms 03 6spd- intake, smarty jr!!
01 reg cab dually 4x4 5spd bhaf raptor 150 and comp box Farmboy 5in 2in steel spacers for the rear with 6 new 305s! injectors on the way!!!!!
kc04 is offline
post #2 of 3 (permalink) Old 04-10-2010, 01:54 PM
2nd Gen Guru
Mopar1973Man's Avatar
Don't use the T-tape... You need to get a new sealing washer...
Mopar1973Man is offline
post #3 of 3 (permalink) Old 04-11-2010, 05:17 PM
Did you get a full set of injectors from F1 diesel, or were they used from someone else? IIRC F1 sets there pop pressure to 280 bar so I would give them a call and double check. If they were just the tips, i didnt think F1 sold just tips for the vp trucks.
3406 Nozzles SMN Medium and Heavy Duty 28 04-15-2010 04:34 PM
80 to 100% over nozzles camojeeper Ford Parts wanted 0 11-03-2009 04:43 AM
150hp ats nozzles 92cummins Whats Been Sold 8 08-05-2007 09:56 PM
Injector nozzles. BogginF350 2003-2007 6.0L Power Stroke 4 04-28-2007 08:32 PM
Edge nozzles RED DRAGON 5.9L Cummins (1998.5-2002) 18 11-01-2006 09:29 PM
