ladder/traction bars - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by O2CUMMINS, this thread has received 19 replies and been viewed 7399 times.
post #1 of 20 (permalink) Old 04-12-2010, 02:43 AM Thread Starter
O2CUMMINS's Avatar
Send a message via Yahoo to O2CUMMINS
It has been a while since my last post. I have been pretty busy. I noticed the other day that I have some pretty bad axle wrap and I need to correct this issue. I was looking into traction bars, but they seem to restrict the articulation, but it seems that no one makes a true ladder bar for the newer
2nd gen trucks, due to the factory sway bar. Is the sway bar really needed if you run ladder bars? If so, Maybe I could run traction bars with a hinged front joint. Any info on this would be greatly appreciated. Sorry for such a long post.
2002 Cummins 24v 6speed Grandrock 6" Aussies, : ADRENALINE , BHAF with k&n intake tube, Autometer pyro, boost & Fuel pressure gauge, 100 HP sticks, FASS, new injection pump. Valair DD and 62/65/12 charger.
:smoke
O2CUMMINS is offline
post #2 of 20 (permalink) Old 04-13-2010, 10:17 PM Thread Starter
O2CUMMINS's Avatar
No one??
:smoke
post #3 of 20 (permalink) Old 04-13-2010, 10:41 PM
SSpeeDEMONSS's Avatar
i dont see why you need a sway bar. a lot of the newer fords dont have them. i know mine doesnt and it doesnt affect anything unless i have a high load in the bed.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
The Following User Says Thank You to SSpeeDEMONSS For this addition to TDG:
O2CUMMINS (04-14-2010)
post #4 of 20 (permalink) Old 04-14-2010, 02:14 AM
gone fishin!
rear sway bar makes a big difference when hauling heavy......takes alot fo sway out of bumper pull trailers. but a good solid ladder bar setup will act like a sway bar to.
MABB- members against big business
keep the internet free!!!!!!!!
floridaboy is offline
The Following User Says Thank You to floridaboy For this addition to TDG:
post #5 of 20 (permalink) Old 04-14-2010, 05:48 AM
The closer you can get the traction bar to match the arc of the springs as they compress and extend, the less binding you will have with them. Generally speaking, matching the angle of the drive shaft will get you close to this. The drive shaft is designed and run at the angles it is, to use the slip joint as little as possible under normal and basic articulation. This limits the wear on it. So matching that angle will put you near the angle you want for a traction bar.
For my regular cab long box truck, it seems as though a traction bar that is 60" eye to eye mounted to a bracket on the lower shock mounts at the bottom of the axle and to the frame on the other end is about right. Still building them, but I will let you know how they work when I finally get them all buttoned up.
The Following User Says Thank You to sstockton For this addition to TDG:
post #6 of 20 (permalink) Old 04-14-2010, 10:27 PM Thread Starter
O2CUMMINS's Avatar
Sean,
Would you post some pics when you get them done?
:smoke
post #7 of 20 (permalink) Old 04-15-2010, 04:40 AM
Does anyone know of a manufacture that sells a kit or anything?
Carbur8tr is offline
post #8 of 20 (permalink) Old 04-15-2010, 11:57 AM Thread Starter
O2CUMMINS's Avatar
There are a few for traction bars, but as for ladder bars they do not make them for 2nd gens. You can check out lazar smith, but that style would be easy to build and a lot cheaper.
:smoke
post #9 of 20 (permalink) Old 04-23-2010, 03:31 AM
I will for sure. I am going to get them all tacked up next week.
post #10 of 20 (permalink) Old 04-24-2010, 05:38 PM
Generally speaking, how does the ride change?
traction bars or ladder bars olred07 2008-2010 Body & Suspension 1 01-11-2010 09:26 PM
Traction-Ladder Bars VengeanceEnt Everything Else 0 11-19-2009 05:39 PM
Traction or ladder bars better for towing? skav 1994-2003 7.3L Power Stroke 9 05-06-2008 03:39 AM
Ladder Bars and Traction Bars Jays7.3 General Ford Truck and Excursion 7 01-24-2008 02:23 AM
ladder traction bars? blood General Ford Truck and Excursion 108 09-27-2007 11:48 PM
