injectors vs nozzles - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by robot, this thread has received 15 replies and been viewed 14251 times.
post #1 of 16 (permalink) Old 04-12-2010, 10:44 PM Thread Starter
hey i was wondering what the advantage new injectors have over just the nozzles. i imagine once a certain hp is reached, a new injector is recommended. i want to go 100-120 hp over, should i get new nozzles or whole new injectors?
robot is offline
post #2 of 16 (permalink) Old 04-12-2010, 11:57 PM
whole injector from a quality company. no jammers. I like ddp and mach
01quadcab is offline
post #3 of 16 (permalink) Old 04-13-2010, 12:53 AM
Injectors arend't that horribly spendy. Just go full body and then you don't have to screw with the pop off's and stuff.
#23 B.O.M.B. Squad[/B]
rwhite is offline
post #4 of 16 (permalink) Old 04-16-2010, 07:29 PM
IDImonsterstack's Avatar
ive got 100hp BD nozzels in mine never had them popped and work great
under the knife for rebuild
IDImonsterstack is offline
post #5 of 16 (permalink) Old 04-19-2010, 02:13 PM
2nd Gen Guru
Mopar1973Man's Avatar
Like I found out putting new nozzles on a wore body is asking for troubles anyways... Like the others here said go with full body injectors you'll have better results...
Mopar1973Man is offline
post #6 of 16 (permalink) Old 04-20-2010, 03:07 PM
Of Course
I love this comment. F1 and DDP both require cores, what do you think they do with them? There is no issue using a core body, especially in a 24v application.
That Guy is offline
post #7 of 16 (permalink) Old 04-20-2010, 04:10 PM
2nd Gen Guru
There is a slight difference...
In your own garage you don't have the means to verify the body is in good shape or condition when F1 & DDP have the tools and the ability to test the bodies to make sure there serviceable... If not DDP or F1 replace the wore or damaged parts... Where Common Joe in his garage doesn't have a clue...
What do you think most of all VP44 are? (Remanufactured...)
post #8 of 16 (permalink) Old 04-20-2010, 05:01 PM
Of Course
What parts of the injector need to be serviced or replaced? Tools or means to test the injector body?
That Guy is offline
post #9 of 16 (permalink) Old 04-20-2010, 05:58 PM
2nd Gen Guru
Like a guy showed my in a Injection shop in Lewiston, ID there is several pieces to the injector including the needle, shims, spring, etc...
So like if you needle is wore and put a new nozzle against it... It might leak, mis-fire, etc... Then the nozzle might be a bit different and require pop-testing/matching...
Like I got a set of RV275 in my truck now that mis randomly... Because there just wore out basically... I asked him if I could just replace the nozzles and come to find out when he tore a wore injector apart in front of me and showed me the wore out parts then I knew there is no way to just put nozzles on to fix the problem.
But in the same sense you can't put fresh nozzle against a wore needle and expect it to not leak or pop correctly...
It's nice when a injection shop puts on a mini-class and teaches you why certain things work or don't work...
post #10 of 16 (permalink) Old 04-20-2010, 08:01 PM
Of Course
What you are saying makes no sense. Nozzles/pintles are a matched set, when you replace the nozzle both pieces are new. The only part that I have replaced in the last 40-50 sets are sleeve nuts if they split. And yes, I build injectors 5-7 days a week. I have also exchanged pintles in used nozzles to make them "pop" correctly, often removing the carbon from the tip and lapping them does the trick.
That Guy is offline
Nozzles kc04 5.9L Cummins (1998.5-2002) 2 04-11-2010 05:17 PM
Aftermarket Injectors/Injector Nozzles stroker smoker_lb7 Duramax 2001-2004 (LB7) 3 02-01-2010 03:24 PM
6.0L stock injectors w/bigger nozzles HeavyAssault Supporting Vendors Forum 3 01-13-2010 10:08 PM
Nozzles Vs Injectors Sabbath5.9 5.9L Cummins (2003-2007.5) 12 03-27-2008 07:38 AM
SMARTY and nozzles or injectors??? RED DRAGON 5.9L Cummins (1998.5-2002) 2 10-11-2006 03:47 AM
