bad turbo?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by IDImonsterstack, this thread has received 8 replies and been viewed 4444 times.
post #1 of 9 (permalink) Old 04-17-2010, 06:53 AM Thread Starter
IDImonsterstack's Avatar
bad turbo??
i think my turbo may be ready to blow. today i was pulling a hill at 28psi and 1400F and i noticed like a exhaust leak sound and it really loud now and the turbo screams. when your off the throttle theres no sound but as soon as i build any boost the noise is there it sounds like a leak but cant find any at all???
under the knife for rebuild
IDImonsterstack is offline
post #2 of 9 (permalink) Old 04-17-2010, 12:14 PM
milkin cowboy
MILKINGCOWBOY's Avatar
Send a message via AIM to MILKINGCOWBOY
1,400 lil hot for my liking first off! When im pulling hard I hear like "wooosh" sound around 27 psi or so right up to 32 or so it sounds like the waste gates dumping but I still maintain full boost. Runs fine when making this noise IDK? My turbo screams any way with the little mods I do have I run real heavy most the time to in hilly country.
2002 3500 6 speed ex. cab 4x4 custom flatbed farm truck 9,120 lbs. light weight ALL WAYS HAULIN HAY, CATTLE OR A-$-$!!!! BHAF,4" OPEN STACKS,EDGE JUICE WITH ATTITUDE, AIR DOG II 100,SOUTH BEND CLUTCH
1982 IH Transtar Eagle 4370 turned up 400 Cummins big cam, straight 6" bull haulers one hell of a
Jake and 13 speed od
White 2-105 tractor with 354 Perkins
White 2-135 tractor with 478 White/Hercules
KEEP ON KEEPIN ON
SUPPORT AMERICAS DAIRY FARMS
http://i17.tinypic.com/4u2drv8.jpg
http://profile.myspace.com/index.cfm...ndid=137814954
MILKINGCOWBOY is offline
post #3 of 9 (permalink) Old 04-17-2010, 02:17 PM Thread Starter
yeah no loss in power but turbo sounfs totally different
post #4 of 9 (permalink) Old 04-17-2010, 04:22 PM
Could it be the cooling fan clutch?
later is offline
post #5 of 9 (permalink) Old 04-17-2010, 06:23 PM Thread Starter
checked that and its good. when i start it theres a small puff of soot by the turbo so im thinkin the turbo flange gasket blew out or a manifold gasket
post #6 of 9 (permalink) Old 04-19-2010, 06:38 AM Thread Starter
found out what it is now lol talk about a bunch of stuff wrong the flange gasket on the turbo is blown out on the botto mand the gasket on hte back of the trubo elbow is blown out and a teh manifold has a craxk in it between the 3rd and 4th cylinder just waiting for parts to get here so i can fix it now
post #7 of 9 (permalink) Old 04-19-2010, 01:14 PM
milkin cowboy
Glad to hear that you found it. Now my 2 cents would say that those problems more then likely came from running hot for more than a few seconds and high boost while she was hot
KEEP ON KEEPIN ON
post #8 of 9 (permalink) Old 04-19-2010, 02:15 PM
2nd Gen Guru
Mopar1973Man's Avatar
Check your turbo for damages...
http://mopar.mopar1973man.com/cummin...urbo/turbo.htm
Then check your exhaust for leaks, holes, or crack manifold... Sometimes the manifold crack on the underside... So crawl under the truck and look up at it...
Mopar1973Man is offline
post #9 of 9 (permalink) Old 04-20-2010, 06:12 AM Thread Starter
the turbo is in great shape i just overhauled it bout 3 weeks about and got about 1000 miles on it. the gasket on the back of the turbo is blown out on the bottom bblack soot everywhere and the t3 gasket is blown out on the bottom.with both those gaskets blown my truck is smoking real bad and my milage is cut in half to the point im driving my chevy dually with a 502 casue its gettin better milage my truck is getting bout 9mpg with the leaks.
Isspro Turbo monitor or Turbo timer proud1 1994-2003 7.3L Power Stroke 4 03-11-2010 11:46 PM
1991 Ford 7.3 Non Turbo I Need To Figure Out How To Turbo It blacksmokeobs 7.3L and 6.9 IDI (Pre 1994) 7 04-01-2009 12:51 AM
E350 psd turbo vs F350 psd turbo ichthus 2003-2007 6.0L Power Stroke 5 06-08-2007 04:15 AM
Wanted: Early 99 PSD Turbo Pedistal with or without turbo. WyoDieselCowboy Whats Been Sold 3 04-22-2007 09:20 PM
Very oily tube post turbo. Means Bad turbo seals? I10HaulR 2003-2007 6.0L Power Stroke 1 03-07-2007 10:59 PM
